Tool Talk Discussion Forum
Homelite Generator
Roy Suomi
09-12-2006 22:54:40
I just purchased a Homelite 5000 watt generator from Ebay..It's got a cast iron Briggs engine on it..Wind-up rope start..Any idea what horespower this is..Old owner says it's 8 hp..I don't think so..Looks too big for 8 hp..I'll have numbers tomorrow when I pick it up..Just curious..
mph
09-13-2006 12:02:08
 Re: Homelite Generator in reply to Roy Suomi, 09-12-2006 22:54:40
I have a Homelite 5500, it has a 11hp. B&S syncho-balanced industrial/commericial engine. elc. and manual [rope] start. But I do not think it would put out 5500 for very long mabey a cond. 4000.
naz
09-13-2006 03:18:13
I have a Homelite LR5000T generator,it is a 10HP.
I have the book here if there is anything you need to know from it?
Naz
oliver power
09-13-2006 03:00:41
I had two 4400 watt homelites. They had 8 HP briggs as you described. The weight from the air breather , as well as vibration , broke the carb on both generators.
teej
09-12-2006 23:38:19
Takes 2HP to produce 1000 watts. a 5000 watt continuous generator would require a 10hp minimum engine.
But, manufactuers like to play with the numbers. Some will advertise a 5000 watt generator, but upon closer inspection, you find its really only 4000 watts, with a 5000 watt surge. Meaning, it can only produce 4000 watts continuously, but can produce 5000 for a few seconds to handle start up surges of electrical devices. In this case, an 8hp engine could work, but it wouldn't be the best configuration.
