Tool Talk Discussion Forum
O2 Regulator.
Jim@concordfarms.
09-12-2006 01:04:47
I have an old Union Carbide two stage oxygen regulator that has trouble maintaining a stable line pressure. It does okay at higher pressures used when cutting, but when I try to use it at a lower setting like around 8-10 psi for brazing the pressure flucuates so badly that I can't use it. I had it rebuilt about 10 years ago by my gas supplier (Indiana Oxygen) for the same problem. Now it's doing the same thing again. I thought 2 stage regulators were better at keeping the line pressure steady than single stage were. Do I need a new regulator, or is there something they're overlooking? Thanks. Jim.
circus
09-12-2006 05:40:07
 Re: O2 Regulator. in reply to Jim@concordfarms., 09-12-2006 01:04:47
Sounds like a diaphram hole. Open cyl. valve slowly to avoid pressure shock.
