Tool Talk Discussion Forum
Wheel Question
Dug
09-10-2006 19:15:42
When I parkd my JD 2510 this evening, I noticed I had lost one of the bolts out of the center of my rear wheel. There are three bolts that tighten the wheel and two bolts are used to push the wheel off. One the bolts used to push the wheel off is the one I lost. Shouldn't be any harm in continuing to use the tractor with the bolt missing, is there?
msb
09-10-2006 19:28:13
 Re: Wheel Question in reply to Dug, 09-10-2006 19:15:42
No problem.They are held in with a soft iron u clamp that is squeezed closed ,but the inner cone needs to be removed to installl the clamp.The jack bolt doesn't need to be clamped to loosen the cone.
Dug
09-11-2006 19:27:58
 Re: Wheel Question in reply to msb, 09-10-2006 19:28:13
Thanks for the reply. I'll just leave it like it is...I pulled that wheel once and hope I never have to do it again.
