Tool Talk Discussion Forum
Pop Quiz (Batteries)
john in la
09-09-2006 10:21:19
Someone help me threw this brain dead moment we get when getting older.
If I have 2- 12V batteries and hook them together what do I get and which one is called series and which one is parallel.
1) + of one battery to - of other battery.
In other words a lead from starter to + of one battery; a jumper from - of this battery to + of other battery and then - of this battery to ground.
2) + and - of one battery to + and - of other battery
In other words both +'s hooked to starter and both -'s hooked to ground.
Man I hate getting old!!!!! !!!!
Thanks.
Charles (in GA)
09-09-2006 11:06:33
 Re: Pop Quiz (Batteries) in reply to john in la, 09-09-2006 10:21:19
#1 describes a series connection and the result is 24 volts, the amps is no more than one of the batteries is rated at.
#2 describes a parallel connection and the result is 12 volts and the amperage of both batteries combined, more oomph or amps to last longer cranking.
Charles
old
09-09-2006 10:53:44
Well to get 24 volts you hook + to- and then the + of one to the starter etc and the - to ground, and thats 24 volts and is called series. If you hook them + to + and - to - thats parreal and you have more amps but still 12 volts. Hope that explains it well enough
