Tool Talk Discussion Forum
goat fences
spitz
09-08-2006 09:30:11
What kind of electric fence do I need for goats? its about a 15 acre pasture. How big of fencer and how many strands of wire?? These are boer goats and reeasonbly docile. Help!! I dont want to chase these things!!
Dale in Ar.
09-10-2006 21:18:03
 Re: goat fences in reply to spitz, 09-08-2006 09:30:11
I had a small problem of young goats getting out through my elec. fence.Spaced my wires every 4 inches on the first 4 wires then 8 inches .Bottom wire was ground wire,next wire was hot ,then another ground,another hot.Then I went and got a 50 mile rated charger,10,000 volts.Now the goats stay in,for now anyway.My advice,get the biggest charger you can get over 10,000 volts,may be costly but well worth it.
jdemaris
09-09-2006 05:18:51
In my experience, it all depends on the goat breed - and even then - there are always are few that are a bit more "creative" about escape than others. I raised Tennessee Fainting Goats for 20 years, but have also had some Nubians, Alpines, Spanish Meat (scrub) goats, and later - Boer crosses. I did well enough with with five-strand, high-power electric fence (three hot, two ground). But, with that being said - any time that fence was out, they knew it - almost immediately. Then, there is the issue of kids - that are small, charge through the fence, and then get stuck on the outside. Once the other goats see that, they get bolder and spend much of their time trying to follow. And - also - the bucks in rut. If you have bucks - good luck. A buck in the mood for a date with a female cares little about electric fence. And, the Tennesse Fainting Goats often go into a rut twice a year. I had one buck that got a hot-fence wire stuck in his mouth - and I have no idea how long he was stuck. When I first found him, I though he was dead - and I got zapped just trying to drag him off until I turned the fence off. He did recover though - but he always seemed a bit demented after that. In fact, he later became a kid-killer, and in-turn, we killed him. Ultimately, I gave up. With new goat-sale regulations in New York State involving health certification - even for auction meat-goats, it wasn't worth it. And, even with 50 acres of fenced goat-land, they always want to go somewhere new - usually some city-person's manicured lawn or dwarf apple orchard somewhere. I had the County Sheriff called on me several times - involving travelling goats and also my chickens. In most of New York - chickens still have "free range" status. They can go roam around City Hall if they choose and it's legal. But goats? No, free range ended around 1820. And, they'll ruin a fruit tree by debarking in record time.
vally farm
09-08-2006 18:52:55
I've had goats for about 15 yrs now, and I tried everything all the books said. From ele. pos/neg every 6 inches, to ele. barbed wire...the only thing MY goats show any respect to is paige wire fencing. Could have run 220 on the hot wires, yea they would bleat loud as heaven, but then finnish going through. Good luck Mike
old
09-08-2006 10:17:16
In my web site you can see what we use for are goats. Just go to the goat page and you will see then fnce and the goats
Dachshund
09-08-2006 09:46:15
You will have to train the goats to the fence so they don't get caught in the electric wires. I use 7 strands, the bottom one being about 3" off of the ground. then space the wires up about 6' apart. Electrify the bottom, 3rd and 5th wire. Typically, when I fence pasture for goats I put woven wire on the bottom and then run 2-3-or 4 strands of barbed on the top (depends on how tall the woven id). I have had good luck with this. Besure to put the wire on the "goat side" of the fence and the posts no more than 12' apart. It is also a good idea to put a wood post in every 4th or 5th post (or more). A goat LOVES to rub against a fence! If you can, get "goat fence" woven wire - this has the openings small enough that the goats won't stick thier heads thru and get thier horns caught. I have over 2 miles worth of woven that I got free from farmers that were getting rid of it. Ask around, you might get lucky.
