Tool Talk Discussion Forum
which fencer?
rambler
09-08-2006 06:37:00
Pardon my spelling:
Galegher or Zebara? Which is better - those are the 2 available 'round here? Going for a 50 or 100 mile 110v set up, keep those hooved critters attention on the inside of the pasture, not looking outside....
hobbyfarmerinWI
09-11-2006 17:46:27
 Re: which fencer? in reply to rambler, 09-08-2006 06:37:00
I have a Galligaer (sp?). I have a 3 joule unit running two wires that works great. Lower wire will be put into the weeds when I am opening a new area, and it burns through them just fine. Total run is just under 2 miles
Shovelman
09-09-2006 04:25:57
Try a Parmak - I think you will pleased. Not the cheapest, but tough, dependable and serviceable.
Scott
Here"s a link:
barnrat
09-09-2006 04:06:39
I've had Gallagher, Zebara, and now have Paramark. I like the Parmark the best. All three were rated the same, 100 miles or x amount of joules. I run a single or double wire energerized fence for dairy cows and heifers encompassing about 100 acres broken into 10 to 1 acre paddocks. I've never taken a reading of less then 6000 volts with the Parmark, even when there was alot of vegatation on the fence. The other 2 fencers would draw right down to less then 1000 volts and sooner or later the heifers would figure that out. 1000 volts dosn't bother them a bit.
Jerry/MT
09-08-2006 10:52:04
I use a charger sold by Premier in Iowa. It's called a wide impedence charger because the voltage doen't fall off as fast with load as a low impedence charger. They're pricey but I live in an area where the natural rainfall is low and low impedence chargers like Gallagher (which I have used very sucessfully in higher rainfall areas) don't perform well in dry conditions without going to a dual wire set up (one hot and one ground). You can look at Premier on www.premier1supplies.com
Coloken
09-08-2006 07:42:53
50 or 100 mile? man, would I hate to be you range rider...Kenny
paul
09-08-2006 08:11:04
 Re: which fencer? in reply to Coloken, 09-08-2006 07:42:53
I find those numbers meaningless, actually. They rate them at the point they are no longer useful - like shop vac or air compressor motor hp ratings these days - 6hp rating off a 110v 20 amp plug???? :) Nope, doesn't compute.
5 or 10 mile fencers don't cut it if you have 2 miles of wire - a few weeds & dew and you got nothing that bothers holstien crosses any more....
--->Paul
CECattle
09-08-2006 07:33:35
Ditch both and find someplace to get a Parmak, The company,Parker McCrory, is based out of Kansas City, MO. Great chargers.
dan hill
10-05-2006 03:53:02
 Re: which fencer? in reply to CECattle, 09-08-2006 07:33:35
I repair fence chargers, Parmak is the only co. with reasonable repair parts pricing.You will need repairs when lightning strikes.Just spent a lot of time finding a Speedrite transformer.Price I got was 67.00 plus 11.00 shipping my cost.Parmak transformers sell for 25.00 to my customers and I have 4 on the shelf.Buy a Parmak charger from a shop that can repair it.Zareba chargers have the output transformer epoxied to the circuit board.If a transformer fails you have to replace the entire insides of the charger.40.00 the last I knew plus 9.00 shipping.
youngfart
09-08-2006 07:25:49
go with zabra because galiger never worked as good for me i own two galies and two zabras, the zabras hold the cows the galies never held anything.
