Tool Talk Discussion Forum
Two questions about electricity
Stan in Oly, WA
09-06-2006 20:21:39
There are two basic issues I've never understood about electricity. 1) How does an appliance determine the amount of current it gets? If I plug a 500W heater into a regular 120V outlet and turn it to its highest setting, it uses 500W of electricity. If I plug a night light with a 7W bulb into the same outlet it uses 7W of electricity. Why? Since a much greater amount of current is available why doesn't it burn up the filament in the bulb? If I am welding with a 3/32" stick electrode at 90 amps, turning the current up to 200 amps will burn it up. Why not the filament?
2) Why does a person get electrocuted if a radio falls into the bathtub with them? Say the tub is cast iron and the supply and drain pipes and fittings are brass and galvanized steel---very typical scenario when Sean Connery was James Bond. Say the system is grounded to both the plumbing and grounding rods, also SOP at that time. If the bather is sitting in dirty bath water, isn't the water a better conductor than a human body? Why doesn't the electricity run from the appliance through the water to the plumbing, short the system and blow the fuse or trip the breaker? (Pre GFCI.)
These and a few more answers to perplexing questions and I'll probably start being able to sleep nights.
Thanks, Stan
jmixigo
09-07-2006 09:12:10
 Re: Two questions about electricity in reply to Stan in Oly, WA, 09-06-2006 20:21:39
There are some truly excellent minds attending this forum. Some of them electrical engineers. Many of us however are but simple folk.
To translate: if you air smart enuff you can allways figger out whut it kin do. you kin offen figger whut it will do. you kin sumtime figger whut it mite do. and don't nobudy no why it duz all that.
bad spelers uf the wurld UNTITE!
John T
09-07-2006 04:11:03
Here Ya go an Engineers take on your interesting questions..... .....
QUESTION 1) How does an appliance determine the amount of current it gets? If I plug a 500W heater into a regular 120V outlet and turn it to its highest setting, it uses 500W of electricity. If I plug a night light with a 7W bulb into the same outlet it uses 7W of electricity. Why? Since a much greater amount of current is available why doesn't it burn up the filament in the bulb? If I am welding with a 3/32" stick electrode at 90 amps, turning the current up to 200 amps will burn it up. Why not the filament?
ANSWER: Ohms Law is that I = V/R..... . The house voltage is a constant 120 volts sooooo oo the current the appliance draws depends on its Resistance, the less resistance the more current draw and the more power (Volts x Amps) the appliance consumes. The fact that the home service can "supply" more amps does NOT defeat Ohms Law, the current and resultant power depends on the loads resistance..... GET IT ?????
When you crank the amps setting up on your welder, it increases the transformers output voltage, and again since I = V/R, moreeeee eee current flows..... . buttttt in the home the Voltage is constant at 120 volts so changing the resistance (like a 100 watt bulb versus a 1500 watt heater) changes the current n resultant power GET IT ????? ????
QUESTION 2
One gets electrocuted when current flows through the body, especially through the heart, making it defibrilate and the pump looses its prime OUCHHHHH can really ruin your day. If the bathtub itself has a path to ground via the pipes,,,,, ,, and youre sittin in it immersed in conductive water,,,,, ,,,and 120 volts is introduced into the water,,,,, ,, current is seeking a return path anywhere n everywhere it can find it with most flowing throught the least resistive path sooooo oooo one possible path, REGARDLESS IF ITS THE LEAST RESISTIVE is through the human body sittin in the water sooooo o thats how you can get fried GET IT????? ??? Its no matter that the water or the body is the lesser or more resistive, current is seeking any n all paths with more current through the least resistive buttttt ttt some can find a path through the body to fryyyyy yy James Bond sitting there nekid lol
The resistance of bath water versus the human body (which is like 80% water) depends on the water and its mineral content and other contaminents but if youre immersed in conductive water and theres 120 volts between you n that water verus the tub and its plumbing someeeee eee of that current is going through youuuuu OUCH
PART TWO Why dont the pre GFCI breaker trip?? It takes like 20 amps to trip the breaker but remember Ohms Law (I = V/R) and the resistance of the water and/or the body PLUS THE RESISTANCE OF MOTHER EARTH (see below) is like reallyyyyy y high sooooo o the current draw is wayyyyy yy less then 20 amps to trip the breaker but still enough to defibrilate your ticker OUCH. A GFCI however trips at like 5 milliamps so it might save the bather yayyyyy yyyyy
PART THREE.... Why is there current flow anyway in the plumbing which has a connection to buried water pipes????? ?? Thats cuz at the homes service entrance and out on the transformer pole the Neutral is tied to mother earth via driven ground rods or connections to buried water pipes etc sooooo oooo the 120 volts when the appliance tossed in the tub is FIRST seeking a return current path back to the transformers Neutral, a part of which will flow throught the water right back over to the other side of the appliances heating element buttttt ttttg theres another path, albeit higher in resistance, through the water and the tubs pipes to mother earth and through mother earth to the transformers Neutral which happens also to be tied to earth sooooo oo thats the current path that can pop your ticker OUCHHHHH HHHh
Hope this helps n dont cornfuse ya
John T, retired Electrical Engineer in Indiana
Stan in Oly, WA
09-08-2006 09:36:21
 Re: Two questions about electricity in reply to John T, 09-07-2006 04:11:03
Hi John,
What's up with the "GET IT?????"? I realize that you're a flamboyant writer, but how do you figure that "GET IT?????" doesn't come across as patronizing, or like you're totally at the end of your patience? It took me by surprise because it seems totally out of character for you. You seem like a completely nice person and very generous about sharing your knowledge. I'm not so thin skinned that it irritated me or hurt my feelings, but after mulling it over I thought maybe you'd appreciate a word because I'll bet you didn't mean it that way. (Or maybe you did; maybe there's an unexpected vein of pi$$ and vinegar in the retired EE from Indiana. That would be all right, too,)
All the best, Stan
old
09-07-2006 21:54:15
John, can you please drop me an e-mail I have a couple questions for you.
MarkB_MI
09-07-2006 04:09:43
The easiest way to understand the relationship between voltage and current is to make an analogy to something you can put your hands on. The most commonly used analogy is water flow in a pipe.
Think of voltage as pressure in a water tank. Think of current as flow through a pipe exiting the tank through a valve. As we open the valve, we reduce the resistance to water flow and the flow rate increases, even though we have not increased the pressure in the tank. Also, the rate that energy is dissipated from the tank increases as the flow increases. Power is nothing more than the rate that energy is used or produced, so if we are filling the tank with a pump, the pump will need more power as we open the valve.
In mathematical terms, voltage equals current times resistance (V=IR, aka Ohm's law). Power equals voltage times current (P=VI). So, in your two examples:
500W heater: I=P/V=500W/120V=4.2 amps R=V/I=120V/4.2A=28 ohms
7W light bulb: I=P/V=7W/120V=.058 amps (58 milliamps) R=V/I=120V/.058A=2100 ohms
Now this is true for DC. It's also true for purely resistive AC loads. (Heaters and light bulbs are resistive loads.) Things get more complicated with reactive AC loads, such as motors, due the the phase angle between voltage and current. But that's another lesson.
As far as getting shocked in the tub, I think most of the fatalities involve someone touching or using an electrical appliance that is outside the tub while in the water. The victims body completes the circuit to ground via the house plumbing.
T_Bone
09-07-2006 19:16:51
 Re: Two questions about electricity in reply to MarkB_MI, 09-07-2006 04:09:43
Hi Mark,
What a great straight forward simple explantion Mark!
As too can the radio or hair dryer kill in the bath tub. I ran into a woman 25yrs ago that lost her 6yr old son because he stood up in the bath tub an pulled in the hair dryer and turned it on at the same time. She said he yelped one time and she went running but it was too late.
They put a large home builder out of business as the owner was taking the GFI out of the bathroom after each inspection to install it the next house.
Two years later I had read where her hsband who was head of the State Contractor Pest Control board was aked to resign as he wouldn't issue any new licenses in the town where he owned two pest control companys.
T_Bone
jmixigo
09-06-2006 22:13:48
I don't really know either but I did get some good learning on the subject from a patient retired shop teacher who lives across the road.
He said: Look at electricity like water. Wires like pipes. Volts are pressure and amps are volume. Watts are compilation of amps multiplied times volts, so if amps or volts go up so do watts BUT if volts go up times two (220) and amps come down to less than half of what was needed at 110 then you get the same work out of less juice.
I said OK
He said: to make it work you gotta get it in and you gotta get it out, so how fast you let it out controlls how fast it comes in.
And just like water leaks just make a mess.
I hope that you too are now as confused as I am, though that ain't likely.
being wrong is a good oportunity to learn-and all my exwives were good teachers.
Stan in Oly, WA
09-06-2006 22:53:39
 Re: Two questions about electricity in reply to jmixigo, 09-06-2006 22:13:48
Hi Jimmy,
I think you and I are a lot alike---find a lot of things to be a letdown but pretty funny anyway. My first wife and I found that we didn't fight as much if she stayed in Honolulu where she owned a bar, and I stayed in Seattle where I could afford to buy houses and renovate them. I was hopeful that it would work out (although that seems pretty stupid now.) One time I met her at SeaTac airport and remarked that her flight was a little late. Her response was, "Don't start." I saw then that it was all over but the shouting. When I left that woman, I don't think she'd had a chance to teach me a tenth of what she intended to.
Thanks for the electricity info, too, Stan
Bob
09-06-2006 22:44:46
Gosh, I wish folks would take electricity for what it is, and learn to understand it WITHOUT the water and pipes and valves analogy!!!
jeffcat
09-07-2006 19:27:34
 Re: Two questions about electricity in reply to Bob, 09-06-2006 22:44:46
Hey Bob you're right but it is an easy way to tell someone. Now think of this for a few. Water doesn't like to go up hill but electricity sure does! When you use the plumbing system you realy shuld lay the pipes flat on the ground to do the same as real water. Now when you get into electronics you start getting half flowin water valves, valves that give more water than they get. ALL KINDS OF NEAT STUFF. Actually if you understand how steam engines work and how water injectors work with vacuum and venturas....awwww skip it!! Jeffcat
jmixigo
09-06-2006 22:23:17
TV program Myth Busters tested that radio in the bath tub thing -also hairdriers, and a TV. As best as I understand it you could, under PERFECT conditions, bump someone off like that once in a thousand tries.
Then they said, "Don't try this at home, cause we'er not responsible either way it goes. Electricity killing a person is very unpredictable."
buickanddeere
09-06-2006 21:45:48
Resistance is different between the lamp and heater. Similar in effect to opening a water valve farther and increasing flow ( to a point anyways). Heater has the "valve open farther" than the lamp. A Welding arc is an ionized, low resistance coloum of plasma. The welding arc and also the arc inside a flourescent tube start off as high resistance. Once the arc is struck they noth become low resistance. That is why the welder's core and the flourescent lamps ballast is a current limiting saturable reactive magnetic core. Otherwise bot arc are a short circuit. The laws of physics as portrayed on a TV or in movies are usually 1/2 truths at best.
old
09-06-2006 21:40:23
Well the old hair drier falling in the tub thing was busted on a TV show not long ago if you can believe that. But it all has to do with the thing called OHMs law and E=MC squared and a lot of other tech terms. Years ago I could have explained it but I don't like Zap-U-Trons and working with them so I stopped doing it for the most part 20 plus years ago and only use what I need now days. But to say the least its has a lot to do with math and how things work and unless your into all that stuff lets just say thats how it is. If not then theres 1000s of books that wil explain it
circus
09-06-2006 20:34:24
How come if the voltage is high enough that bulb can power a city? What is voltage? is it like different colors of light?
John T
09-07-2006 04:20:39
 Re: Two questions about electricity in reply to circus, 09-06-2006 20:34:24
First you gotta consider Voltage as between and relative to two points. Its the Electromotive Force (EMF) between two points and the higher it is the moreeeee ee currrent would really love to flow over to the other side. If the voltage is high enough and/or the distance short enough, current can arc jump and flow acros the path like when 20,000 volts causes current arc across a spark plugs gap. Voltage across 2 points is kinda like water pressure, the more the pressure the more water flow (current) through the pipes just as the more voltage the more current that flows through the wires. Voltage is kinda like Potential Energy, it takes energy (the utility company) to elevate voltage at one point above another and then its just sititn there ready willing n able to expend that energy in the form of volts x amps (watts) through an appliance.
Yall take care now n God Bless Im headed to a tractor show for the weekend yayyyyy yyyyy
John T John T
circus
09-08-2006 04:07:49
 Re: Two questions about electricity in reply to John T, 09-07-2006 04:20:39
your plumbing model of electricity volt=pressure, amp=amount is that pressure infers differing speeds. The speed is a constant (light). My model is volt=pressure wave frequency, amps=amplitude within a media. Light. So happens wire is tranparent to these colors.
