Tool Talk Discussion Forum
Speaking of multimeters
Tim B from MA
09-06-2006 18:53:34
I bought a ca $20 Sperry analog multimeter from Lowes a couple years ago. In the last few months I've checked voltage output from several different automotive batteries, including 3 or 4 brand new ones and the charger never reads more than 10 or 11 volts. Same with hot wire to charging systems; the voltage only goes up a couple tenths compared to the battery output.
I assume the meter is just off (yes, I zero the needle as per instructions) rather than new 3 new batteries all being bad.
Anyone else have similar experiences with cheap meters.
Any recommendations for better ones in the, say, less than $50 range?
MarkB_MI
09-06-2006 19:13:07
 Re: Speaking of multimeters in reply to Tim B from MA, 09-06-2006 18:53:34
I haven't used that particular meter, but even a cheap meter should be with +/- 10 percent.
There may be a problem with your technique. Are you by any chance using the AC range? If this meter is peak averaging (as most cheap meters are), then it's going to read about 9 volts for a 13 volt DC input.
If you want a good meter, get a Fluke. If you prefer analog, look for an old, reliable Simpson 260. If you just want a cheap meter, well, I think they're all pretty much the same. Which is not that bad these days.
