Tool Talk Discussion Forum
Air Pressure Regulator Shopping
Glenn FitzGeral
09-06-2006 16:25:59
I'm gearing up to re-roof my house. I need to install a regulator on my 2 stage air compressor system to get the pressure down to the 90# the nailer calls for. Grainger had no idea what I was talking about. All the other stores I checked except NAPA only had twinkie little ones rated at 125-150#. NAPA has one starting at $62 and going up to $200+. How much should I pay for a good one, and where would you get it?
As always, I appreciate your expertize, Glenn F.
DR.EVIL
09-07-2006 15:34:32
 Re: Air Pressure Regulator Shopping in reply to Glenn FitzGerald, 09-06-2006 16:25:59
Get one with the buit-in coalescing air filter. I got My Porter-Cable at Farm & Fleet. I suspect TSC or any farm & home center, even the Big Box stores would have them. You don't need much air flow to run a nailer.
JOHN HARMON
09-06-2006 20:41:31
Got mine at Checkers Auto Supply several years ago. Works good especially with Air Nailers and Paint Sprayers needing a lower PSI.Good moisture collector too.Reasonable in cost also.
circus
09-06-2006 20:05:41
Can get regulator wherever pneumatic tools are sold. check out Harbor Freight
Charles (in GA)
09-06-2006 19:27:02
Look in MSC, Grainger, McMaster-Carr, etc. also look at www.surpluscenter.com as they have some from time to time.
Charles
kent
09-06-2006 17:52:27
LOOK ON EBAY---I BOUGHT A GOOD, NEW REGULATOR & WATER SEPARATOR FOR LESS THAN $20.00---HTH
KENT
Rod (NH)
09-06-2006 17:22:12
Hi Glenn,
I have a Watts regulator I bought 5 years ago for $37.00, model R119-04C, rated at 300 psi inlet. Watts is a division of Parker Hannifin. It's a relieving style and works fine. I have never had a problem with it. Conversely, I purchased a Sharp regulator for another station a couple of years ago (forgot cost and didn't keep sales slip). That worked fine for a while but after about a year the diaphragm began to leak. And that's downstream from a filtration train down to 0.01 micron. I love the Watts but am quite disappointed with the Sharp. I probably got the Sharp at NAPA but am not sure. I got the Watts from a local industrial distributor.
third party image Rod
fzbcheve
09-06-2006 17:05:33
we just purchased a 3/4" regulator from McMaster-Carr out of Chicago. Its made for just what you need. Cost with shipping was about $57.00.
