Tool Talk Discussion Forum
anyused a spoolgun on a crackerbox vs batteries?
souNdguy
09-06-2006 08:16:25
Comments?
Soundguy
CaptRon
09-08-2006 18:51:26
 Re: anyused a spoolgun on a crackerbox vs batterie in reply to souNdguy, 09-06-2006 08:16:25
SoundGuy,
Don't take our word on this subject, read it for yourself on the ReadyWelder website. It also answers the question about using a buzzbox for power.
Keep in mind also that I can verify that everything presented on the website is true and factual.
CaptRon
CaptRon
09-08-2006 18:41:09
I also have a ReadyWelder that I weld aluminum and steel with. It does a good job and I've used it for a couple of years now. I've used batteries in the past for stick welding and tig welding stainless steel and mild steel. Always works fine and with a few tricks you can control the heat too. Thinking of getting a bottle of CO2 mix for welding solid core wire however, the outside work would have to be on a windless day. That's the good part of flux cored wire, it can be used when the wind is howling.
Don't knock it till you try it, and you can't beat the price. I've run 10-12 spools of aluminum and 6 spools of steel through mine without a single problem. I'd buy another one in a minute.
CaptRon
jmixigo
09-06-2006 09:55:24
Thanx Stan you just brightened my day.
I needed that.
Stan in Oly, WA
09-06-2006 09:09:27
Hi Soundguy,
Wirefeed welders are constant voltage output, stick welders are constant current. I've read that you can't successfully run a wirefeed unit using a CC power source for your arc. OTOH, I've stick welded using car batteries. So if you run a spoolgun by itself from batteries, then I obviously don't have enough information to do anything but waste your time by posting it.
Don't thank me; knowing I haven't helped is reward enough.
All the best anyway, Stan
souNdguy
09-06-2006 12:17:36
 Re: anyused a spoolgun on a crackerbox vs batterie in reply to Stan in Oly, WA, 09-06-2006 09:09:27
I like that post.. funny.. I may even rip it off..
As for the batteries.. i saw a spoolgun in a catalog that was made to be used with 2-3 car batteries.. use dthe small flux wire packs...
Soundguy
T_Bone
09-06-2006 16:12:36
 Re: anyused a spoolgun on a crackerbox vs batterie in reply to souNdguy, 09-06-2006 12:17:36
LMAO Stan,
Well I gave the same type advice that Stan did a couple years ago but last year while I was spec'ing a new engine driven welder, I found I was behind times as now most new spool guns can be used on CC/CV. What I don't know is how they accomplish such in the circuit. I didn't take the time to learn why.
I've also seen ads at Northern Tool??? (HF???) a spoolgun that works off of battery power.
If that's true then I can not see why any DC power source can't be used.
The true question is how well does the equipment weld??? Enough to get you out of a jam??? Surely not quality welds???
I hate to bad mouth something I haven't used. I did that to a Century FCAW machine and had to eat my words as it ran a very decent bead for a $300 cost.
T_Bone
SteveinCT
09-06-2006 17:50:37
 Re: anyused a spoolgun on a crackerbox vs batterie in reply to T_Bone, 09-06-2006 16:12:36
T_bone, I have owned a battery powered Readywelder for 5 years now and I have welded a lot of different widths and have had good success with it. My welds have gotten better and better, no problems with weld quality or penetration, but honestly, the batteries do get hot after a half an hour or so. Good machine.
souNdguy
09-06-2006 17:26:30
Well, I've seen people battery "stick" weld with 2-3 car batteries and it was just like a dc buzzbox. I assume that if a battery can put out 475 cca.. then it can put out the welding amperage that a stick welder would do as well... Not sure how long you get? 15 minutes maybee?
I'm sur ethe batteries don't really appreciate it either..
Soundguy
T_Bone
09-07-2006 19:39:26
 Re: anyused a spoolgun on a crackerbox vs batterie in reply to souNdguy, 09-06-2006 17:26:30
Hi Soundguy,
If I was going to use battery's I would use the Trojan T-105 6v battery's as they could with stand the constant discharge.
At 80amps welding current using 3/32" rods you could get about 2hrs of welding time using two battery's.
I'll have to try it one time and see the results.
As Steve pointed out I may be surprised.
T_Bone
souNdguy
09-07-2006 19:54:15
 Re: anyused a spoolgun on a crackerbox vs batterie in reply to T_Bone, 09-07-2006 19:39:26
Wouldn't you need to get the electrode voltage up to the 22-32v range for welding.. thus needing 4 6v batts?
Soundguy
Stan in Oly, WA
09-07-2006 23:03:24
 Re: anyused a spoolgun on a crackerbox vs batterie in reply to souNdguy, 09-07-2006 19:54:15
Hi Soundguy,
When I used batteries for stick welding, they were the 6V Trojan deep cycle ones that T_bone mentioned. There were six of them connected in series in a golf cart. I disconnected two so that I would have 24V which I estimated to be about right. I used either 1/8 or 3/32 (I don't remember) 6013 because I find it to be one of the least finnicky rods. My leads were heavy duty jumper cables. The arc was too hot for the work which was welding links of < 1/4" steel chain. The jumper cables got hot, too. I threw a dry cotton towel over the tops of the batteries to reduce the possibility of a spark igniting the hydrogen gas. I would have appreciated more distance from the batteries, or a brisk wind.
All the best, Stan
T_Bone
09-08-2006 01:14:08
 Re: anyused a spoolgun on a crackerbox vs batterie in reply to Stan in Oly, WA, 09-07-2006 23:03:24
Hi Soundguy,
Yep I was thinking two sets of two and just got side tracked. Should be about 22dcv for 6010/7018 usage. Could be you need a 5th one for voltage drop too???
Hi Stan,
I don't think the hydrogen gas would be a problem but I would be more concerned if I was recharging the battery's as then off gassing would be highest.
Without anyway to contol amperage, I would think it would be difficult to weld very long before the electrode over heated??? Maybe letting the voltage drop would be a good thing???
Interesting idea tho. I use 6-T105's in my RV and when I get a chance I'll have to play around with it as one should be able to hit a happy medium between voltage, electrode size and welding speed.
T_Bone
