Tool Talk Discussion Forum
Multi task pressure gauge.
J Schwiebert
09-06-2006 06:47:53
30 plus years ago when I worked for a dealer we had a combination pressure gauge. There were 3 gauges in a round cluster with one hose. Hook it up and it would give you any reading between 30 inches of vacuum or 4-5000 psi. Anybody know the correct name and if they are still available? Thanks in advance J.
J Schwiebert
09-06-2006 15:30:16
 Re: Multi task pressure gauge. in reply to J Schwiebert, 09-06-2006 06:47:53
Thanks to all wo responded. It was a Micro gauge and I have also seen the Cat units. They are lareger in physical size and since they say Cat probably more money. I called Micro and they hooked me up with a local distributor. Thanks again
Joe (Wa)
09-06-2006 12:42:28
I think you are probably looking for a Mico quadrigage as depicted at this link. I have one like the red one and you are right about "30 years ago" LOL.
The gauge ranges on mine are Left side 30" - 0 - 150 psi
Right side 0 - 600 psi
Top 0 - 3000 psi
Joe
kent
09-06-2006 12:16:46
I HAVE SEEN THOSE AND I THINK THEY ARE A CATERPILLAR SPECIAL TOOL---YOU MIGHT TRY A CAT DEALER----HTH
KENT
neblincr
09-06-2006 11:12:20
Or a Big$$$ from....
neblinc
09-06-2006 11:09:21
Here is one I found, does not go as high as you stated.
Randy
