Tool Talk Discussion Forum
I can't be the only person who ever needed this...
Ryan - WI
09-04-2006 19:43:21
I need a new diaphragm for a mechanical fuel pump on a CH18. I have been looking all over the internet for a part number for that and I am officially nowhere. Even Kohler doesn"t list the parts seperately, just the fuel pump and rocker cover all together as a kit.
Anyone have experience with the Command series that might know where to find the part number?
jack12345
09-05-2006 20:30:31
 Re: I can't be the only person who ever needed thi in reply to Ryan - WI, 09-04-2006 19:43:21
I had same problem I used some Black rtv to repair diaphragm still working good.
Jim K
09-05-2006 16:05:08
Just a thought, but try making your own out of inner tube, or something similar. just be sure that it is fuel compatible.
Good luck
Jim K
Areo
09-05-2006 17:13:25
 Re: I can't be the only person who ever needed thi in reply to Jim K, 09-05-2006 16:05:08
I just recently had the same problem. Used a piece of "rubber roofing" for the diaphram.
Areo
Weldin Man
09-05-2006 09:17:07
Fuel pump went out on my Lincoln Welder. Kohler replaced it under warrenty. They replaced the entire valve cover assembly.I asked the man who fixed it why ,he said that was the only way you could get it from Kohler.
