Tool Talk Discussion Forum
Antifreezes for hot water heat?
JD Gentleman
09-04-2006 18:25:33
I have had water in my hot water heat pipes for years, but now i would like to use antifreeze in them. What kind and how much should i use? Right now i have water in the 1st floor pipes only, but i would like to heat my 2nd floor at times. If i have antifreeze in the pipes, will it keep the 2nd floor pipes from freezing if i do not heat it?
workhorse
09-04-2006 19:40:14
 Re: Antifreezes for hot water heat? in reply to JD Gentleman, 09-04-2006 18:25:33
Propylene Glycol is a food grade anti-freeze that will protect your system to below zero. You can find it in wally world, the pink rv anti-freeze. A good hvac company would have it in bulk and could install it for you.
john *.?-!.* cub owner
09-04-2006 20:20:49
 Re: Antifreezes for hot water heat? in reply to workhorse, 09-04-2006 19:40:14
propylene glycol is also what is used in the water lines of my geothermal system.
