Tool Talk Discussion Forum
two cycle engine problems
swms301
09-04-2006 15:03:23
I was given an old weed eater and a Lawnboy mower. The weed eater hasn't been used in over 5 years, the mower at least 2 years. Both had old mixed gas in tanks. Any tips for cleaning or flushing the old gas from the fuel lines and carburetor?
I got the mower to start twice and run for about 10 seconds each time but hasn't started since then.
I can't seem to get any spark from the weed eater. Can't see a spark or feel a spark when i pull the cord. Have I acquired some green scrap iron?
Any help appreciated.
swms301
09-05-2006 07:32:24
 Re: two cycle engine problems in reply to swms301, 09-04-2006 15:03:23
Thanks for the advice. Two out of three say go for it! So I will.
msb
09-04-2006 18:51:38
Just dump the old gas out and refill with fresh gas.On a 2 cycle that has not been run for that long, you will probably have to replace the diaphram in the carburetor.They dry out after setting that long as a rule and will not suck gasoline out of the tank & into the carburetor as a result.
The weedeater flywheel has probably gotten rusty and it and the coil legs will need to be sanded.
Neither is a big job.
Tim B from MA
09-04-2006 18:33:59
Yea, my father-in-law gave me two Lawnboy mowers, up till that point, I thought he liked me.
Scrap iron! or aluminum or white metal, what ever the heck those useless pieces of junk are made of.
Rod in Smiths Falls, ON,
09-05-2006 18:35:30
 Re: two cycle engine problems in reply to Tim B from MA, 09-04-2006 18:33:59
Try plastic. My sister brought me an old Lawn Boy knockoff sold by Canadian Tire. This thing had a kitchen pot scraper as an air filter. The plastic tank and plastic air filter were nothing. This thing had a plastic carburetor. It was easy to take apart, I'll grant that.
No amount of persuasion would revive this turkey, though it would run for ten seconds if I gave it a drink through the carburetor. The plastic gas cap had disintegrated, the float was crusted with rusty looking goop, and the seals were long gone. A missing plastic plug in the back of the air cleaner would have provided a ram jet of dirty air to the carb if it ever ran. It joined the other three dead lawn mowers in the barn.
john *.?-!.* cub owner
09-04-2006 20:23:22
Don"t forget that on a 2 cycel the crankshaft seals have to be good for them to draw enough fuel to start
