Tool Talk Discussion Forum
Blackhawk S23 Floorjack - Won't Lift
Randy McClenaha
09-03-2006 13:21:39
I have a Blackhawk jack that was leaking. I replaced the seals and gaskets and the leaking has stopped. My trouble is that the cylinder rod does not extend. What did I do wrong?
Randy
Randy McClenahan
09-06-2006 17:51:47
 Re: Blackhawk S23 Floorjack - Won't Lift in reply to Randy McClenahan, 09-03-2006 13:21:39
Thanks folks. I bled the jack as you suggested and it works fine, without any leaks. My grandkids can rebuild it next time.
Randy
10K PSI
09-03-2006 17:35:45
The S23 is a pretty heavy duty oldy goldie, you should be ok if you didn't mess up anything in the valves. To bleed the air, open the release valve 1/2 turn or so and pump wth a full stroke (all the way up & down) 5 or 6 times. Close release firmly and it should go all the way up & hold. I'll try to remember to look at a print when I get back to work Tues to see if there's anything tricky about this one assembly or tool-wise, it's been a while since I last did one.
Rustyj14
09-03-2006 16:22:02
You will probably have to bleed the system, that is-get the air out of it. Check with a mechanic or somebody who fixes hydraulic equipment, to find out how to do it!
