Tool Talk Discussion Forum
Battery Damage
VaTom
09-03-2006 06:26:55
Energizer akaline battery sprung a leak and ruined my Mag-Lite. Their packaging doesn't say what Duracell's does, about repairing/replacing anything damaged by their batteries.
I found a web site and, with difficulty, found a phone number to call next week. No address offered. Looks like either their batteries never cause a problem or they don't want to talk about it. The Duracell phone number/address was on the battery packaging.
Does anybody have experience with Energizer (Eveready Battery Co.) making good on damage their product causes?
JiminIA
09-03-2006 17:33:48
 Re: Battery Damage in reply to VaTom, 09-03-2006 06:26:55
I have a 3 D cell maglite that has a corroded battery in it that I cannot get out it is the middle one. I have soaked it with oil etc and still can't get it out. Anyone have any ideas?? Sorry to hijack the thread but it just got me thinking. Thanks, Jim
Harold Hubbard
09-04-2006 05:36:22
 Re: Battery Damage in reply to JiminIA, 09-03-2006 17:33:48
I had one that did that, and I figured it was useless unless it was fixed, so I put the cap back on without the spring, and smacked it endways on a block of wood until the battery moved a little, oiled it some more pounded it back in with a hammer handle, repeated until it finally came out. New batteries wouldn't go in until I wrapped some sandpaper around a big dowel and cleaned up the inside of the barrel with it. If you do this, make sure the cap is screwed on tight when you hit it, and strike a quick sharp blow, squarely on the cap, and not too hard.
If this hadn't worked I would have tried to figure out some way to destroy the battery and get it out piece by piece
MI Mark
09-03-2006 16:09:47
Sounds like we left the batteries in to long then expect someone else to cover our butt for it .
BigMarv1085
09-03-2006 13:55:45
I ahve owned at least 20 maglights. Had one that the batteries caused corrosion inside. I pulled out the swiches and all removable parts, cleaned it with acid etch and treated with alodine. Then painted the inside with primer. 15 years later it still works. The biggest problem I have is the switches don't last so I have 14 in a box that don't work. It's about as cheap to just buy another one than to package up and send back.
Dale B
09-03-2006 08:56:54
Maglite also has a lifetime warrenty. They have a website, and here is the phone # 909 947 1006 If the battery co won't cover it , maybe Maglite will..... .....
