Tool Talk Discussion Forum
Cylinder to my disc will not retract....
Donald M
09-01-2006 15:26:23
This cylinder had not been in use for about two months and when I began to attach it to the Disc I inadvertanly extended it and thus could not attach the other end without retracting it. Is this just a matter of "bleeding" it to get it to retract. I have lossened the bleed plug and tried to retract the cylinder to no avail. It is a relatively new cylinder. The hydraulic pump on the tractor is fine since it will operate other cylinders. Any ideas would be appreciated.
Eric in IL
09-01-2006 16:20:54
 Re: Cylinder to my disc will not retract.... in reply to Donald M, 09-01-2006 15:26:23
If it is a single acting cylinder (one hose) leave it attached to the tractor, hold hydraulic lever in the "down" position and you should be able to push the cylinder closed by hand.
