Tool Talk Discussion Forum
Powermatic 180 planer with blade sharpener
Mike S
09-01-2006 06:30:48
Just bought one of these monsters last night and while I can find a reprint of the regular manual, cannot locate info on the blade sharpener that is mounted on the top of it. Anybody got a copy of the instructions for it that they would share? Or could point me to a place that would have it? I tried Powermatic website and could not locate it other than being told the 180 is not longer in production. Thanks
Bus Driver
09-02-2006 14:53:16
 Re: Powermatic 180 planer with blade sharpener in reply to Mike S, 09-01-2006 06:30:48
I am not sure which model this is. Back in 1965, we had a Powermatic planer that had worm and pinion drive on the feed rollers. The pinion was brass or bronze and was ruined. We bought a new pinion gear and it ruined in just few minutes. We did not why and abandoned the planer. I now believe that it was the 90wt. gear oil we used, the smelly kind that cars used at the time. It has additives, sulphur perhaps, that help the steel gears but will kill brass and bronze. If your Powermatic has any bronze gears, be sure to select the lube carefully.
Bernoulli/OR
09-02-2006 06:32:37
Here's another website. It is dedicated to the restoration and use of old woodworking machines.
http://www.owwm.org/
Gus
09-02-2006 04:26:52
Check out this site. Yhere is so much there it might take you a while to find where you want to be. It's a start anyway. Good luck. Gus
Gus
09-02-2006 04:28:47
 Re: Powermatic 180 planer with blade sharpener in reply to Gus, 09-02-2006 04:26:52
Try again. Link
