Tool Talk Discussion Forum
O.T. GM Engines, 5.7 vs. 5.3 (5300)
Johnski
08-31-2006 17:52:54
Hi All, I lurk here often in this big ol" bowl of knowledge soup dippin" in every so often to fish out a good chunk and droppin" in a little myself from time to time. I"m looking to replace my pickup(95 F-150) with a suburban to tow my camper that weighs about 7000 lbs. Should I look for a 1999 to stay with the 350 engine or a 2000 and up with the 5300? I know those year 350"s had a few problems with the EFI and intake gaskets but I know nothing at all about the newer motors as I"ve been working on Heavy Equip and diesels for the last 6 years. All opinions are welcome, thanks in advance. Jf
Mike M
09-01-2006 20:28:42
 Re: O.T. GM Engines, 5.7 vs. 5.3 (5300) in reply to Johnski, 08-31-2006 17:52:54
As a current Ford owner you may be better off staying with Fords. I have had some of each and while I really liked the GM trucks they drove me nuts with all the problems that cropped up. I now have a 1996 Dodge with a 360 gas with 160,000 miles and it has been a very good truck.
buickanddeere
09-01-2006 01:58:34
As previously stated. Once you own/drive the LS series engines in the 4.8,5.3,6.0, 6.2, 7.0 etc. The old Snoretech 350 is just an underpowered fuel waster. The 350's made a strong case for ordering diesel engines instead.Now the LS engines in some circustances are preferable over a diesel.
BLT
08-31-2006 19:14:50
Looks like I am the exception, I don't want another 5.3! I owned a 96 Tahoe with the 350, never a minutes trouble, traded it in on a new 2000 with the 5.3. Big mistake, the 5.3 was under powered and would not get the gas mileage the 350 did, traded it off after 17 months and bought a crew cab with the 6.0, now that is a great engine. It now has 103k miles on and won't use any oil. I use it to tow my goosneck hauling my tractors and it does a good job.
Bob
08-31-2006 19:51:35
 Re: O.T. GM Engines, 5.7 vs. 5.3 (5300) in reply to BLT, 08-31-2006 19:14:50
The 4.8, 5.3, and 6.0 are ALL in the same engine family, basically derivatives of the LS-1 performance engine.
So, outside of your bad luck in getting a 5.3 with problems, the 6.0 should be no better, only more HPO, as it is the same design.
MarkB_MI
08-31-2006 19:01:59
How many 1999 model pickups have you come across with less than 200,000 miles? That '99 is nearly eight years old.
The 5300 is newer and mo'better.
Johnski
09-01-2006 07:17:07
 Re: O.T. GM Engines, 5.7 vs. 5.3 (5300) in reply to MarkB_MI, 08-31-2006 19:01:59
No problem finding 98"s and 99"s with low mileage up here in Kennedy country(MA), the soccer moms and yuppies don"t have too far to drive. That said I think I"ll look for an 00"-03" with a 5300 motor.Thanks for the input Jf
landlord7012
08-31-2006 18:58:13
I bought a 99 chev w/5.3 from local contractor with 230,000 miles on it. Currently have 259,000 on it. Sounds like a thresher when it starts (short piston skirts slappin' around until first couple revs) BUT it runs great! 1/2 qt oil every 3000 miles. Pulls 5000 lbs (properly balanced) effortlessly. Not sure when piston slap problem was resolved at assembly though...
ll
jmixigo
08-31-2006 18:07:48
My father in law bought a 2000 Chevy std duty 3/4 ton with that engine in it new. I own it now. Two sets of plugs and wires, one water pump, one set of hoses and belts. Must have been a defective water pump 'cause it only lasted 208,000 miles. Now at 212,000 mi it has started useing almost a whole quart of oil between 5,000 mile changes.
I like mine-gets about 7 or 8 mpg more than the '95 with a 350 in it that I had before.
