Tool Talk Discussion Forum
8 volt vs 6 volt battery
Matt in PA
08-31-2006 09:08:25
I was talking to a guy the other day at an auction and explaining to him that my Farmall H did not turn over very fast with a fresh 6 volt battery. He suggested putting in an 8 volt. I have never heard of this before. He runs one in his H and "it works great". Is this realistic and how does the 6 volt system charge the 8 volt? Maybe, he was just trying to snow me! What do you guys think? Matt
Bill in IN
09-01-2006 04:06:04
 Re: 8 volt vs 6 volt battery in reply to Matt in PA, 08-31-2006 09:08:25
Been rinning an 8 volt for years. Works for me.
Duke(WNY)
09-01-2006 03:23:06
Why don't you just get your starter rebuilt. Just had one rebuilt for an 8N for 70.00.
george md
08-31-2006 16:34:52
Matt, Something over 30 years ago ,I was working on an AG-6 cletrac that was slow or almost no crank .I
had cleaned and shined all the connections both
hot and ground ,put brushes , bushings and new
armature in it and still no better. I was on the
way to a starter rebuilder with some other ones,
so I took it along, the owner of the shop looked
at the starter and said - that starter will spin
any engine that it is designed to bolt on. I dont't know for sure what he did , but when I put
it back on the crawler it would spin that engine
at or better than idle speed. It cost 12 dollars
to fix . I think he set the brush timing but I'm
not sure. It was a 6 volt system , and still cranks well .
george
Tim Casbolt
08-31-2006 16:05:28
The parts to convert to 12 volt are very inexpensive. Gotta wonder why folks wouldn't want to skip the whole 6 or 8 dilemma, not to mention those dumb old generators, and go straight to an internally regulated alternator with a $40 battery. Unless you're trying to keep it pure stock for the show circuit, in which case money is no object.
Robin Mach
08-31-2006 13:10:49
To chime in on what John T. said...
My MH-44 didn't start worth a darn. Then I got rid of the Wal-mart battery cables and bolt on cable ends for a good set of 00 gauge cables and it starts like a new one.
John T
08-31-2006 10:30:27
Matt, assuming all other things equal, its true an 8 volt battery would indeed make the starter crank faster. However, Im NOT a fan of the 8 volt system and view it as a band aid approach to mask the real problem and since a lil H ought to start okay with the standard and original 6 volt system provided alllll ll is in good condition.
As far as charging, if your charging system is the simple 2 wire cutout relay it ought to still work and if its a Voltage Regulator with Current Regulation but not Voltage Regulation it ought to still work, but if its one of those 3 coil VR's that has independant Voltage Regulation it may need to be adjusted n tweaked up some for better charging. If the genny is a 3 brush adjustable unit I would set its third brush to the max charge position also.
At 8 volts the lights will glow brighter but burn out sooner and likewise, the points will not last quite as long plus the coil (if a battery powered coil ignition) could run a tad on the warm side unless some external ballasting were used.
On 6 volt systems I recommend the heaviest duty highest rated battery that will physically fit in the compartment plus the use of 00 Gauge Battery n Starter n Ground Cables and if the starter is in good shape, that combination ought to start a lil H just fine if it and the ignition are in decent shape at all.
Its your tractor and your choice so best wishes n let us know.
John T
jones in texas
08-31-2006 09:17:51
I have installed a number of 8 volt batteries in place of 6 volts and they have worked good. You may have to adjust the voltage regulator for higher output.You will need about 9 volt output.
spitz
08-31-2006 09:12:12
I use the 8 volt on all my 6 volt tractors. They charge fine and turn over much better.
