Tool Talk Discussion Forum
Three way valve
Slowpoke
08-31-2006 02:02:16
I'm looking to buy a large three way valve that can be used with 2" ABS black pipe. It needs to be plastic but all I can find are small 1/2" and 3/4" brass valves. Home Depot only has straight thru ball valves in 2" plastic. I want to have water go straight thru or be diverted 90� into another pipe. Any one know of a source or have one sitting on a shelf in the garage (if such a thing exists)?
Thanks
Stan in Oly, WA
08-31-2006 13:05:59
 Re: Three way valve in reply to Slowpoke, 08-31-2006 02:02:16
Hi Slowpoke,
I think you could divert discharge water from a washing machine with only one shutoff. Coming up a 2" pipe on the far side of a low p-trap, put the discharge pipe to the barrel higher or lower than the pipe to the house drain. A shutoff on the lower pipe will determine which way the water goes.
All the best, Stan
Slowpoke
09-01-2006 00:09:40
 Re: Three way valve in reply to Stan in Oly, WA, 08-31-2006 13:05:59
I guess that's the only economical way to go. I can't see spending $130 for a plastic three way valve to save 10 cents worth of water. I'll put a shut off valve in the house drain line and a T with a 4" riser before it. Thanks for the idea.
Dave Sherburne NY
08-31-2006 10:29:35
I'm pretty sure you can find 3way plastic valves
used on weed sprayers. Try Link Oh,,its $88
TomTX
08-31-2006 06:44:30
Can't you just use 2 valves; one on the straight pipe and one on the other pipe? Tom
PaulW_NJ
08-31-2006 04:56:55
Try Grainger. Here"s a 2 inch. I"d think anyone carrying irrigation supply equipment (farm supply) would have them as well.
Slowpoke
08-31-2006 09:25:18
 Re: Three way valve in reply to PaulW_NJ, 08-31-2006 04:56:55
Surprise....I was looking under "three way valves" which is not listed in the index. Any way, the price is $129 in my Cat#397. At that price, my idea to divert washing machine water from the drain to a storage barrel for use in a garden would be too expensive. I'd still have to add the cost of a barrel and piping.
