Tool Talk Discussion Forum
String Trimmer Problem
Ford Man
08-28-2006 20:43:02
Got a McCulloch Mac 65 gas string trimmer.It is at least 16 years old.
The old gas line finally cracked and so I replaced it about a year ago.It has the filter on one end in the tank and goes thru a hole in the tank to the carb.There was not a grommet or anything like that where the line went thru the tank.
It ran fine until a few weeks ago when it started to spray gas out around the hole where the line went thru the tank.I noticed that when I revved it up , there was a lot of churning and frothing in the gas tank.It does not do that when idling.
I cleaned the filter and the cap and replaced the line and it still does the same thing.
I have even run it without the cap and also without the filter and there is no difference .
Any ideas ?
It sure isn"t safe to run like it is.
Thanks in advance !
Ford Man
