Tool Talk Discussion Forum
O.T. The Fly Vs. Gravity
JOHN HARMON
08-28-2006 18:39:39
While driving down the road at 60 MPH. today I noticed a Fly sitting on the Dash Board.Suddenly he took off ,flew around the cab some and then relanded on the Dash Board. The questions are,
A. Why wasnt he slammed against the back of the Truck Cab? He detached himself from the truck and had no physical way to continue at 60 MPH. to keep up with the Truck.
B. He flew around some and relanded about where he was when I spotted him. How fast did he have to go to catch up with the Dash Board which was traveling 60 MPH. I weigh,well around, 200 Lbs so there is a reseason called Gravity to keep me at the same speed as the Truck plus I was attached by the seat. But this fly probably is so light he can not be weighed and he detaches himself and nothing happens to him. Is there an answer?
shannon from ohio
08-30-2006 16:39:04
 Re: O.T. The Fly Vs. Gravity in reply to JOHN HARMON, 08-28-2006 18:39:39
Gravity's a b i t c h isn't it??
JOHN HARMON
08-29-2006 16:01:37
This is getting better all the time. I think into every ones life a little entertainment is welcome and this is pure entertainment,bar none. thanks every one for making my day a little more enjoyable with so many learned answers at least one of thewm should be near perfect. Every one have a great day until the next time. John
dr.sportster
08-29-2006 15:37:21
You will need to call in the same team of scientists that sits by ones bed and counts the number of spiders ingested in a lifetime.They probably know.
Don L C
08-29-2006 14:03:50
He is in the same space as you are....you dont fall fack aginst the seat when you let go of the stearing wheel....he is protected by the truck cab....
If you were to remove the windshield and the rear glass..... he would be long gone.....
Gravy
08-29-2006 10:56:03
It's all about the velocity of the air in the cab on which the little b..... is flying. With windows closed the air is going 60 mph. Try opening the windows...whooooosh....
John T
08-29-2006 06:08:29
This dude named Einstein made a pretty good livin pondering a related question and published theories of relativity even lol. He also came up with the theory as an object approaches relativistic speeds (I seldom move that fast) he kinda gets heavier plus he shrinks, something called the Lorentz Einstein time contraction or dilation theory or somethign like that, aint life grand.
John T
2x4
08-28-2006 21:54:59
Have you ever noticed when driving a tractor a fly circles 2" around your head? Double your speed & it still circles 2" away. Quadruple speed & its still circling 2" around your head. I mean... where do they learn the math? ( Little bugger must've attended Bug U.) Amazing what you notice on slow days.
MarkB_MI
08-28-2006 19:51:38
Good question.
You accelerated the fly to 60 mph while he was on the dashboard. When he flew off the dash, there were no forces to decelerate him, so he kept going at 60. As he flew around in the cab, he was accelerating and decelerating relative to the cab, so his instantaneous speed relative to the ground varied between a little faster than sixty and a little slower than sixty. But his average velocity from the time he flew off the dash until he landed was 60 mph.
Here's another thought: Suppose you were to drive your pickup off a cliff. For the purposes of our discussion you have your seat belt off. As your vehicle plummets to the ground, you, the fly, and your pickup are each subjected to the same forces: Vertically, gravity is accelerating you downward at 32 feet per second per second (32 ft/sec^2). Horizontally, there is essentially no force acting on you once your tires lose contact with the ground. Since all three objects start with the same initial velocity and are subjected to the same acceleration, everything hits the ground at the same time, going the same speed.
Here's another example: You're a passenger on an airliner. The plane hits an "air pocket" (actually turbulence) and the stewardess walking down the aisle is momentarily "weightless". Does she slam against the rear bulkhead of the aircraft? Of course not! Even though the plane is flying at 400 mph, the stewardess and the plane are both going the same speed and the stewardess stays in the same horizontal position relative to the plane. (However, the plane was accelerated in the vertical axis, so the stewardess appeared to move verically relative to the plane. Actually the plane moved relative to the stewardess.)
Rauville
08-29-2006 08:23:33
 Re: O.T. The Fly Vs. Gravity in reply to MarkB_MI, 08-28-2006 19:51:38
Somewhat along the same line; what if you are buying groceries on a space station at a distance of 932 miles above the Earth, and you see a special on bananas. You can get 2.2 lbs of bananas for $1.00 or you can get 1 kg of bananas for the same price. Which should you buy? The amount of bananas is determined by its inertial mass. You know that on the surface of the Earth, 1 kilogram weighs precisely 2.2 lbs. However, on the space station, the gravitational acceleration is less than at the surface of the Earth. Thus, 1 kg of bananas weighs less on the space station than it does on Earth. Conversely, in order to weigh in at 2.2 lbs, you need more than 1 kg of bananas. At a height of 932 miles, the gravitational acceleration is down to one half, so that 2.2 lbs of bananas has an inertial mass of 2 kg, and would weigh 4.4 lbs on Earth. So you should definitely buy the 2.2 lbs of bananas for $1.00.
Relating..
08-29-2006 03:31:52
I saw a tv program about "stunt junkies". One crazy guy holds the world's record for jumping motorcycles. He's jumped 310 feet. What I never thought of, and it relates to your statement in the second paragraph "horizontally, there is no force acting on your tires" (while airborne)... That stunt junkie said he can change the "attitude" of his cycle IN THE AIR with the throttle. There's inertia, with more throttle the front goes up against the inertia of the weight of the rear wheel. By applying brake against the spinning tire the front goes down. (If you have the guts to fly far enough to try it)
Charles (in GA)
08-28-2006 19:10:41
You want a real fly question to ponder..... ...
A former boss of mine flew F-4's in the AirForce. One day he had a fly in the cockpit on a flight and it was annoying. Well the cockpit is pressurized and so the fly will not have any trouble flying. So my former boss puts on the oxygen, afterburner climbs to something like 50,000 ft and then slowly depressurizes the cockpit. In air so thin that an airplane barely can fly, and a human cannot live without breathing O2, what does the fly do? Keeps flying around like nothing had happened. The boss repressurized the cockpit and called the war with the fly a draw.
Charles
paul
08-28-2006 18:49:37
The earth is spinning about 900 - 1000 mph. If you jump up off the ground you don't land 400 feet away from where you took off either. :)
The air is moving along with you in the cab at 60 mph, so everything is relative. Fly can't notice the speed of the truck, unless it is on the outside.
--->Paul
Dave Grindle
08-28-2006 20:16:52
 Re: O.T. The Fly Vs. Gravity in reply to paul, 08-28-2006 18:49:37
i just found 4 people with waaaaa y too much time ..... .no , make that 5 ( i just read them all !! )
JOHN HARMON
08-28-2006 21:27:49
 Re: O.T. The Fly Vs. Gravity in reply to Dave Grindle, 08-28-2006 20:16:52
And I have had a good time reading all the responses.Cheers,John
ww
08-29-2006 07:04:34
 Re: O.T. The Fly Vs. Gravity in reply to JOHN HARMON, 08-28-2006 21:27:49
if I jog at the speed of sound will I still hear my walkman? if I drive at the speed of light will my headlights do any good?
