Tool Talk Discussion Forum
McCulloch Chainsaw
gordon schafer
08-28-2006 10:43:47
HI i HAVE A McCulloch Chainsaw and can not get it STARTED. BUT WHEN I SHOOT GAS INTO THE CARBUERATOR IT WILL RUN BUT THEN IT JUST DIES DOES ANYONE KNOW WHAT THE PROBLEM IS AND HOW IT COULD BE FIXED?
Dave Sherburne NY
08-28-2006 19:49:40
 Re: McCulloch Chainsaw in reply to gordon schafer, 08-28-2006 10:43:47
Did this saw set around a while if so, the needle valve is probrobly set up. When I worked on
snowmobiles a long time ago, we used to get them in
at the beginning of every season with the needle valve set up because the owner let them set all
summer without running the gas out of the carb.
We had a small thumb operated pump which we hooked
to the gas intake on the carb and started pumping at about 10 pounds the needle would break loose
and the pressure would drop to zero. presto, carb
fixed. Gimme $15 . Perhaps you could rig up a hand pump and try it. Otherwise, go find a diaphram carb kit because you probrobly can't
get it apart without destroying the diaphrams.
coflyboy
08-28-2006 17:55:44
Old is probably right. Had the same problem. Cleaned the 'stone' filter in the gas tank. Ran good until it clogged again.
old
08-28-2006 10:51:59
Fuel filter that is in the tank maybe clogged or the diaphram in the carb has a hole in it. All it takes is a pin hole in the daiphram to cause that type of problem
