Tool Talk Discussion Forum
Stihl MS 192T??
Tim in New York
08-27-2006 09:16:02
Does anyone own one of these? I need to replace my two 1980 vintage 015's - they are shot. I love to cut wood, but have a bad back. The light weight is appealing, but I'm concerned about the power - this saw uses the same engine as the entry level 170. I do have two larger heavier saws, but I like to use light ones for limbing, cutting poles etc.
Thanks,
Tim in New York
onefarmer
08-27-2006 19:40:42
 Re: Stihl MS 192T?? in reply to Tim in New York, 08-27-2006 09:16:02
third party image
Here is a chart I borrowed from another forum. It shows power to weight ratios and much more. This is for Stihl saws. I use a 026 now called a ms260. I bought it in 1990 and use it to heat my house. I use about 90% wood 10% propane
Tim in New York
08-28-2006 09:40:13
 Re: Stihl MS 192T?? in reply to onefarmer, 08-27-2006 19:40:42
That 6.6 lbs on the 192T is what caught my eye. My other two saws are an 026 and 028. I mostly cut tops, and even the 026 bothers my back after a little while, when I use it for limbing.
Not too concerned with the top handle, as my two old trim saws - 015's, had top handles.
I also looked at the Husky 335 and 334. They're similar arborist saws, are a little more money, and I don't really care for the local Husky dealer. Even thought about buying a 334 from Home Depot.
I'll probably end up with the Stihl from the guy I've been dealing with for 30 years. Hoped I could hear from someone who had used this saw, as he no longer provides demo saws.
Tim
onefarmer
08-28-2006 18:03:46
 Re: Stihl MS 192T?? in reply to Tim in New York, 08-28-2006 09:40:13
Looks like the 015 was about 8.8lbs and the ms192 being 6.6 your saving 2.2 lbs. The 015 had 32cc with the ms192 having 30.1cc with the hp about the same. The ms192 must rev higher to make that power. So looking at it on paper, or in this case, on screen the ms192 would be a nice replacement.
This opinion is worth the amount you paid for it. Your milage may vary.
Dachshund
08-28-2006 05:16:26
Try looking at other brands. I have a Stihl 290 and a Husqvarna Rancher. They are comparable saws, but the Husky is lighter, easier to start and cuts smoother. About the only advantage Stihl has is in the chain, so I converted the Husky over to a .325 (instead of 3/8) like the Stihl. The Husky is 2 years old and the Stihl is about 6 months. Dolmar also makes a good saw.
onefarmer
08-28-2006 06:36:07
 Re: Stihl MS 192T?? in reply to Dachshund, 08-28-2006 05:16:26
They made a chart for Huskys but since I'm a Stihl fan I didn't "borrow" that one. Wish I did now. In the saw color wars, it seems to be between Stihl and Huskys the most and some Dolmar. I guess I'm color blind I just know what works for me. I've used Poulan, Jonsred, Stihl, and Mac. It is the Stihl that made it for me. Never tried a Husky.
onefarmer
08-27-2006 19:45:17
Hurts my back to bend over to. While it may be heavier than what you was thinking. I added a 20" bar to the 026, so I didn't have to bend so far. Made all the differance for me.
`Bernie in MA
08-27-2006 17:05:37
I have a Stihl with the easystart feature. The arthritis was bothering me so much I was using an electric saw w/generator. I went to get a new chain for the electric and saw the one I have. Can start it with 2 fingers on the rope.
Jab
08-27-2006 15:23:49
Tim, the MS192T is a topping saw (t stands for topping). Meaning that it is a saw made to be used with one hand because when you are topping a tree, you would want your other hand to hold on, or to hold a rope to slowly lower the branch you are cutting. Stihl gets alot of money for these saws. A MS192T sells for $509.99, while you can get a comparable hp and bar length saw for closer to $300, the home owners saws, such as the ms290 have plenty of power, but they make your arms feel like they are going to fall off after 10 min of use. The prosaws have more power per pound, although they are run at much higher rpms. The prosaws can be rebuilt if you feel that you will use the saw enough whereas the homeowner saws cannot. With your back problems, it sounds that you are more focoused on power and weight rather than price, so i would recommend a pro saw. Although the 192t is a pro saw i would recommend you look at the MS200, which is made for use with two hands, has more ccs, but weighs about 2 pounds more (about 8 pounds). Good Luck, jab
amo
08-27-2006 13:41:43
i have a pole saw with a 10 inch blade. it is good for trimming limbs and i really like it forcutting limbs , etc off of trees on the ground, you do not have to bend over like with a regular saw.
MarkB_MI
08-27-2006 13:09:40
I believe this is the replacement for the 019T. It is an arborists saw. (The "T" stands for "top handle", I think.)
I have an 019T, and it is great for pruning, particularly when you're working from a ladder. It is not a good general purpose saw. The problem is the handle configuration: it forces you to keep your hands only a few inches apart, so you have very little leverage to control the saw. This is fine for pruning, where you need to work in tight spaces, but it is not good for general use. In fact, it's fairly dangerous.
