Tool Talk Discussion Forum
Electric Die grinder?
JoeK(WI)
08-26-2006 23:20:57
Anyone know of an inexpensive but fairly well built unit of similar nature.Need something like a giant Dremel tool for odd jobs but most die grinders I see are high RPM(even adj ones).Would like to find something more in the speed range of a 3/8 VSR drill motor with a long nose/chuck like a d/g.
Slowpoke
08-29-2006 23:46:51
 Re: Electric Die grinder? in reply to JoeK(WI), 08-26-2006 23:20:57
Check out these two items on ebay: 130020292603 & 120024516137. I suspect the first one is an import and the second one is the real Foredom grinder. Notice the difference in speeds. You could also buy a flexible shaft that will fit on the shaft of a 1/4 or 1/3 hp motor. Check ebay when you want info on things you want to buy. It can be a good learning experience. You can also go to Google for things outside ebay.
bluedice
08-28-2006 18:01:39
Bought a Makita GEO600 a few years ago at a welding shop. Guy there said it wouldnt be enough for tough use but I didn't want to spend a lot of cash. He was right. It bogs right down if you lean on it. Die grinding and using rotary files needs power or things can take a long time to finish.
An elderly friend said "Always buy the best tools you can afford" I think you cant go wrong doing that. You have tools your whole life
Boley
08-27-2006 20:34:30
Dewalt makes a pretty good one.I install ironwork and detention hardware in jails and prisons.We've found them to hold up to fairly heavy use.I think they cost about $125.Fastenal,W.W.Grainger stores usually have them in stock.
Chris(WA)
08-27-2006 07:38:22
Makita makes a good one.I paid about $100 for mine at the local hardware because I needed it right then. I suspect you could find it cheaper here on the internet with a little searching. Its a good solid tool and has stood up to a lot of use.I have not had much luck with Harbor freights power tools in commercial use.But the Makitas do a good job.Now only if Milwaukee still built their tools in the USA.....
Vern-MI
08-27-2006 03:56:45
I bought one of these grinders for $29 on sale at Harbor Freight and it works OK. I would like to find an electric right angle version of this grinder.
Jeff Landuyt
08-27-2006 00:52:00
Well it depends on what you need it for. Dremel does make a flexible shaft that fits most of thier products. I have one for my model railroading and it works great, especially when more control is needed or to get into those tight spots. But personally, I would use a regular die grinder on a tractor. I'm a welder by trade and I have an angle and straight head 1/4 inch pnuematic grinders. You can pick them up at Wal-Maet for less then $100.
