Tool Talk Discussion Forum
Testing for welder polarity
Stan in Oly, WA
08-24-2006 13:36:05
Is there an easy way to determine whether a DC stick welder is set for electrode + or electrode - if the output lugs are unmarked? Earlier this year I bought a used Lincoln Idealarc stick welder, one of the old round top ones. The first and only thing I've done with it so far is to put quick disconnects at the output lugs. Because of its present temporary location I can't use it yet without going to quite a bit of set up trouble. The other evening I used it because the project was worth the trouble. When I finished, I disconnected the welding leads, but later realized that I wasn't familiar enough with the welder to be sure which went where. Fortunately, I discovered that the case has writing with arrows pointing at the lugs; one says "electrode", the other says "work". What if it hadn't, though? How could I test to find out DC+ from DC-?
Thanks, Stan
Stan in Oly, WA
08-25-2006 21:57:45
 Re: Testing for welder polarity in reply to Stan in Oly, WA, 08-24-2006 13:36:05
Thanks for the good information, everyone. The meter across the leads worked fine. I'll be able to get the smoke back in the meter, right? Running beads with 1/8" 7018 at 140 amps on DC+ and DC- side by side made the difference very clear. My hearing isn't trustworthy enough any more to go by only the sound but the difference in appearance of the beads was easy to see. The DC+ bead was smooth and even with the sides tied in well. The DC- was stacked up and ragged---not a bead anyone would be proud of. I appreciate the new knowledge. I figure if I learn one new thing for each two old things I forget, I've only got to hang in there about forty more years to break even.
Stan
T_Bone
08-25-2006 14:24:43
Hi Stan,
Probably the easeier method would be to take a known DCEP electrode and burn a bead while trying both leads as the electrode holder. The smoother of arc's produced would be reverse polarity or DCEP.
Bob's voltmeter would also work but be sure to make the measurement as a shunt connection and not a lead series connection or someone will be replacing a meter.
You could also use a Tig torch with 2%Thorinated tungsten that requires DCEN. If connected DCEP then you will burn the tungsten away when you strike the arc.
T_Bone
Weldin Man
08-24-2006 18:22:46
If you had been welding for about 35 years like I have it would be very simple for you to tell, but I will try to explain the very easiest way I know how to tell. Take a 1/8 7018 rod and set the machine at approx. 130-140 amps. weld a flat bead with a very tight arc, approx 4 in. long, Listen very carefully, if the arc is smooth and does not pop or sputter it is Reverse polarity(Rod Positive]. If it is eratic and makes a distinct popping sound it is on straight polarity {Rod Neg.] Hope this helps
Bob
08-24-2006 15:34:25
Use a Voltmeter.
An analog meter will swing upscale when the polarity of it's leads matches that of the welding wires.
A digital meter will simply show the Volts if the polarity matches, or a (-) sign ahead of the voltage, if it doesn't.
old
08-24-2006 13:52:14
Can't say on that machine but on some of them you can weld either way and you do so because of differant stuff you might be welding. Others will probably explain more/better then I jsut did. I do have one question for you. Is this one that has an engine on it or a plug in type??
Stan in Oly, WA
08-24-2006 17:22:01
 Re: Testing for welder polarity in reply to old, 08-24-2006 13:52:14
Hi Old,
It plugs in. It runs on 220 volt single phase house current. I dropped conduit directly out of the bottom of my outdoor breaker box to install a dedicated welding outlet there. It's on a double pole 50 amp breaker. When I need to get farther away, which is always, I use a 40' extension cord I made by running 3 lengths of #6 stranded copper cable through a garden hose with appropriate plug and outlet on the ends.
The Idealarc welder has a selector for AC, DC+, and DC- so I would still have all three no matter how I connected the leads. AC of course has no polarity, and as far as DC is concerned all that would happen if I accidentally reversed the connections is that when I set the welder for DC+, I would actually be running DC-, and vice versa. My question was is there a way to tell whether you're running DC+ or DC- when you can't get that information from the machine itself.
I've still got that 50lb box of 7014 for you, and you can have some 7024 too if you think you might do any high deposition flat welding (and you don't prefer to do it with wire feed.) I'm currently using it up at the rate of less than 50 pounds a year so the offer should be good for another 5 or 10 years.
All the best, Stan
old
08-24-2006 17:58:05
 Re: Testing for welder polarity in reply to Stan in Oly, WA, 08-24-2006 17:22:01
Sure could use the rod but the way things have been I don't have any money to pay the shipping. I usto use a machine like that one but it had an Hi freq box on top of it to do tic welding. I loved to do tig and at one time could wled a beer can but that was years ago and I don't think I could do it any more. If you can see the arc well enough you can tell whcih way its welding. If the arc goes from the rod to the work then you on + but if it goes the other wya your on -, but I would bet that would really be hard to see LOL
