Tool Talk Discussion Forum
OT white wash recipe
BobOHIO
08-23-2006 20:52:05
I had no idea where to ask this question so figured I'd give this forum a try...you guys know everything. What is the recipe for white wash like you would use on cement walls in a barn? Isn't it made with lime? Thanks
jeffcat
08-25-2006 23:18:20
 Re: OT white wash recipe in reply to BobOHIO, 08-23-2006 20:52:05
Boy can I remember this stuff in the cowbarn. Once a year you need to do it. Cow poo and fly poo and everything else that gets on barn walls. Milk inspecter would make a very nice hint about get it done or ELSE. Blow the whole barn down with an air hose with a nozzle on the end. Rent a 125 compressor and go to town. BOY did a lot of loose stuff come off. Leave all of the light bulbs and tubes in the fixtures! You remove the bulbs and wash them when you finish white washing cause the sockets will never work again! Big truck with a big mixer bin and some kind of pump on it. They would throw several bags of dry lime in the hopper with a garden hose for water and mix up this "wash". They would spray EVERYTHING in sight. Remove all of the bulbs and wash them. Reinstall and turn on the lights. You now have one nice and shiney barn! jeffcat
BobOHIO
08-24-2006 16:27:17
Thanks guys. I appreciate your help. Bob
Bill-KCKs
08-24-2006 21:46:57
 Re: OT white wash recipe in reply to BobOHIO, 08-24-2006 16:27:17
I have a recipe pamphlet from Sturgis Sand & Material in KCK for "White Cement Paint" that is at least 53-years old. Their recipe:
10-lbs waterproof white portland cement
2-lbs Snowflake hydrated lime
1/2-lb salt
Fine white silica sand may be added to improve surface hardness. 5-8 lbs sand to 10-lbs cement
Mixing of Paint: Mix all dry materials except salt thoroughly. To each 10 lbs of dry mixture, add 1.5 quarts of water to which the salt has been dissolved, and mix to a uniform, thick paste. Stir in additional water until paint is of a rich, creamy consistency. Allot to stand about 15-minutes, then remix adding more water if necessary and apply to previously cleaned and dampened surface.
For application, use a brush with short fiber bristles, such as an ordinary scrub brush. Two coats reccommended, 24 hours apart. Keep painted surface damp for several days by sprinkling lightly with water. One gallon of mixed paint will cover approximately 200 square feet...
It's pretty durable stuff. Dad painted the stucco with it in 1953 and again in 1976. It will give you a workout; that brush gets heavy.
BobOHIO
08-25-2006 07:31:27
 Re: OT white wash recipe in reply to Bill-KCKs, 08-24-2006 21:46:57
Thank you Bill for the recipe. I have a small building I fixed up that I would like to try it on. I'll print off your directions. Bob
Rauville
08-24-2006 05:57:16
Probably comes out to the same thing, but the old recipe I remember is for:
1 gallon water
Dissolve 2 lbs. Sodium Chloride (Salt)
Mix in 7 lbs. Hydrated Lime
Greg_Ky
08-23-2006 21:09:33
Here is a link.
