Hi J Schwiebert, Dick has about the most correct explanation of the use of gauge numbers used in the Sheet Metal trades as we always buy metal by weight for the approx thickness that will meet code requirements. By code, 29gauge could range from .0135" to .0179" depending if it was plain carbon steel or stainless steel or coated with galvanized. Brass, Copper & Aluminum always has different weights and deminsions for the same gauge in carbon steel. Any metal of 10ga or more is classified as plate steel and is read in 1/16" incremints. Once again if your buying 1/4" plate, etc, you want to buy using the weight as then you well less likely to be shafted. On large jobs where code was well enforced that called for the manufactures gauge mark to be on each joint of duct. To make sure there was no confusion in the shop we would clean out the metal racks of all scrap and remove existing inventorys. We would buy our stocking metal in rolls 60-1/8" wide x 25000lbs and run that thru a decoiler where it was cut to 10ft length stock for making duct fittings. The duct work it's self was made on the decoiler machine. The 60-1/8" wide was so that we could shear a straight edge of exactly 60" in width. The decoiler info is probably out dated by now as the last I heard they were shearing metal with lazer and cutting the fitting parts on the decoiler machine thus cutting labor by 50%. T_Bone
