Tool Talk Discussion Forum
Bandsaw Blade
Pete7
08-21-2006 15:43:14
Wondering what type of band saw blade to buy. I have a Harbor freight type of bandsaw that uses a 64 1/2" x 1/2" blade. I will be cutting 3/4" by 2 1/4" cold rolled steel and I have a quite a few cuts to make. I can get a bi-metal blade with 18 teeth per inch or a regular blade with less teeth per inch. But I can't seem to find a bi-metal with less then 18tpi. I think less then 18tpi (about 10 ??) would be best, but then I wouldn't have a bi-metal blade. What do you guys think?
Pete
M.R.
08-22-2006 19:01:34
 Re: Bandsaw Blade in reply to Pete7, 08-21-2006 15:43:14
use-enco.com
Pete7
08-22-2006 20:20:12
 Re: Bandsaw Blade in reply to M.R., 08-22-2006 19:01:34
Thanks guys, I sure appreciate your sharing your knowledge/experience.
Charles (in GA)
08-22-2006 17:08:10
I have a HF bandsaw that uses that size blade. I have used Starett and Morse brand (from MSC and Grainger respectively) and they are identical, fabricated from the same material by different companies. What I used was a 18/14 TPI variable pitch, "Matrix II Bimetal" blade. It is a very good blade for general cutting, doesn't chatter with tubing, conduit, angle iron, etc.
These are available in 10/14, 14/18, 14, and 18 TPI.
Go to Grainger, its in their catalog. MSC has the same thing, just more expensive in the Starett brand.
Charles
Butch(OH)
08-22-2006 19:35:54
 Re: Bandsaw Blade in reply to Charles (in GA), 08-22-2006 17:08:10
Like Charles I use the Matrix2 and it's hard to imagine a better band. I use the 10/14 and they flat last forever if I am careful about what goes in the saw. No blade will cut rust, torch slag or hard metal for very long.
oldfarmtractor
08-22-2006 08:24:52
I think I would go out and buy a metal chop saw. They do a great job, the blades are not expensive.
Grub0927
08-21-2006 16:52:47
I have a saw like that(Jet brand) that seemed to break blades too frequently. Mine has step pulleys to slow down the blade (fewer feet/minute) so I dropped it one step. No more broken blades. I use 14tpi and 18tpi blades in a all thicknesses of steel and it works fine. I have a tuna can with cutting oil I dab on w/ an acid brush every so often (cheaper than WD-40)
Have fun and stay sharp.
Grub
BobOHIO
08-21-2006 16:38:18
Pete- I have the same saw from HF and use the 18 TPI for a variety of cuts. I would recommend buying a quality blade. I used to buy the $6 blades and would last a little while then break teeth. I bought a good $20 blade from Starrett and haven't had a problem since.
