Tool Talk Discussion Forum
Quality Plumbing Valves Finish and Utility
Joe MD
08-21-2006 10:49:57
I am in search of high quality valves for some plumbing repairs in our home.
We have shut off valves everywhere, but they are all so corroded I have to turn off at the main to do anything at all. The screw down kind do not seem to work very well so I think I am looking for ball valves.
I can get decent ball valves at the box store for in the walls and basement, but where can I find finish valves that are not plastic junk for under the toilet, sink, etc. etc.
Any good websites?
MARK RED OR GREEN
08-23-2006 18:19:45
 Re: Quality Plumbing Valves Finish and Utility in reply to Joe MD, 08-21-2006 10:49:57
BEEN IN THE PLUMBING BIZ FOR 35 YEARS MAIN LINE SHUT OFF VALVES NEED TO BE BALL AVALVES APOLO NIBCO RED AND WHITE ALL GOOD FOR HOMES AND COMERCIAL USE WE USE THESE IN INDUSTRIAL BUT HIGHEST GRADE FOR FIXTURES THEY MAKE A 1/4 TURN STAINLESS STOP WITCH IS WHAT I WOULD USE FOR MY OWN USE AND ARE NOT REAL COSTLY SHOULD BE ABLE TO FIND ANY OF THESE AT A PLUMBING SUPPLY HOUSE
Ol Chief
08-21-2006 17:41:20
If you are searching for screw down globe or gate valves find a pipe valve and fitting supply company.Then look for Walworth or Lunkenheimer valves.Jenkens is also OK but a little lower quality.All of these are in use on railroads,ships and thruout industry.If you are going first class then buy union bonnet type valves instead of screwed bonnet.You will never regret it.I worked on ships for over 50 years and have seen all kinds and qualities.Check yellow pages for jobbers,or people like Mc Masster Carr as last call due to price.
Stan in Oly, WA
08-21-2006 11:57:10
Hi Joe,
Home Depot, and probably Lowe's, carry Brasscraft brand shutoff valves. They are U.S. made, solid brass body, and are decent looking. I have used them for years and generally been pleased with them. Well, actually, earlier this year I did get one with a cracked body or some other flaw so that I had to replace the faucet supply valve twice to correct the original seeping problem. I wish I'd had that single problem years ago followed by no other problems instead of the other way around. Still, I'm mainly satisfied, with reservations. H.D. sells a Brasscraft supply valve with a 90 degree shutoff, which means it has to be a ball valve.
I'd expect you to be able to find higher quality supplies in a plumbing supply store with a retail department. Be sure you talk to someone who's spent a good deal of time in the field using the equipment they sell rather than just a salesperson. Someone with 30 to 40 years experience would be good.
All the best, Stan
Stan in Oly, WA
08-21-2006 14:22:35
 Re: Quality Plumbing Valves Finish and Utility in reply to Stan in Oly, WA, 08-21-2006 11:57:10
P.S. I was working in the basement a couple of hours after posting my previous response and noticed a Brasscraft 1/2" shutoff valve lying on my workbench. I took it apart to see what it was made of. It was entirely brass except for the valve seat washer and the stem packing washer, naturally. It was a used but good one so it's not completely certain that they are still made entirely of brass. Oh wait, I can check the one I replaced under the bathroom sink (sound of man fumbling in the kitchen junk drawer so he won't have to walk an extra 35' to get a Phillips screwdriver out of his tool box.) Nope, plastic valve stem. Forget everything I said.
Stan
