Tool Talk Discussion Forum
bush hog
Gobind
08-21-2006 05:05:24
I've got to replace the blades on my bush hog SQ600. The owner's manual says I need a 1-11/16 inch socket and that the nut holding it should be tightened to 600 ft/lbs of torque. My question is: Am I going to be able to do this with hand tools or does it require special equipment? Thanks in advance.
BigMarv1085
08-25-2006 18:33:57
 Re: bush hog in reply to Gobind, 08-21-2006 05:05:24
I believe he means a torque multiplier.
CaptRon
08-21-2006 20:25:58
I pulled the blades on my 305 using a 6' cheater pipe on a 3/4" drive breaker bar. This was the first time on this mower and I bent the breaker bar. The next time I did it I used a 1" impact that I bought at Harbor Freight for $100 on sale.
Much better and quicker.
CaptRon
supergrumpy
08-21-2006 12:58:47
depends if they have been off before and how they were put back on
3/4 drive, 6 inch extension on socket thru the hole in the deck, LONG pipe on the breaker bar, get socket on there good the first time
you can get new genuine mushroom headed bolts and blades at dealer not much more expensive than TSC, as cheap as I am I pay the extra, bit of anti-seize on the threads helps for next time
if blades are in decent shape, sharpen them in place with angle grinder and go back to work, grind same amount off each blade
hay
08-21-2006 05:54:20
use the hotwrench. save a lot of time and aggravation. just replace the bolt set.
Rich Va
08-21-2006 05:16:22
The easy way to do it is take a torch and cut the old bolts out and get new bolts. Or you will need a 3/4 drive breaking bar or rachet.Start soaking the bolts with your favorite penetrating oil several days in advance.I've also heard of people standing these things on the edge to make access much better. If you do that be sure it's good and secure.
TimS
08-21-2006 12:17:06
 Re: bush hog in reply to Rich Va, 08-21-2006 05:16:22
I have also head of folks using a torque amplifier to get the needed torque to loosen or tighten those....
van robinson
08-21-2006 19:18:29
 Re: bush hog in reply to TimS, 08-21-2006 12:17:06
Torque amplifier??? Aint that a cheater pipe? LOL!
