Tool Talk Discussion Forum
question about replacing headgaskets
grains
08-20-2006 19:46:44
I replaced the gaskets on a D-17 series 4 and when I tighren down the bolts on the rocker assembly it won't start. because it has no compression and when I back off the bolts it will start and ideas?
JMS/MN
08-21-2006 12:29:00
 Re: question about replacing headgaskets in reply to grains, 08-20-2006 19:46:44
You need to do what Rusty says. You cannot remove/reinstall them and have the same setting on the valve tappets. However, when you say you have no manual for it (I&T AC-17 would be right)- makes me wonder if you torqued the head bolts to the proper setting, in 1 or 2 steps, and in the right sequence. Was the head gasket installed right side up? If not, expect further problems down the road. Procedure is somewhat involved and the manual will walk you through it, same with tappet setting.
grains
08-22-2006 07:16:11
 Re: question about replacing headgaskets in reply to JMS/MN, 08-21-2006 12:29:00
thanks everybody he re adjusted things last night and now it starts easier than ever and I couldn"t even hear it when I was cooking supper. All the new gaskets made a world of difference.
RustyFarmall
08-21-2006 05:12:37
Any time, and I mean any time, the head is removed and replaced, you will have to readjust the rockers to get the proper clearance gap on the valves. Check your manual for the proper procedure.
old art
08-20-2006 20:01:50
why did you take the head off ? did you have it resurfaced loosten the valve adjusters then re adjust them to the proper specks
bill mar
08-20-2006 19:52:22
when you are tightening the rocker assembly are you somehow compressing the valves to where they are open and allowing the the compression to escape?
grains
08-21-2006 06:05:39
 Re: question about replacing headgaskets in reply to bill mar, 08-20-2006 19:52:22
I took the whole thing apart because it had blown a head gasket and the landlord bought a gasket kit and wanted them all changed while the thing was torn apart. We do not have a manual for it and do not know the specs for what to set things at.
