Tool Talk Discussion Forum
Welding exhaust manifold
KEH
08-19-2006 15:49:08
I seem to remember hearing that welding holes in a cast iron exhaust manifold would not work because of some change in the cast iron over time. Can someone explain this to me? The manifold that brought the question up is beyond repair, so this question is just for information. It had been brazed on in the distant past so I wonder if brazing would work better than welding. Thanks.
KEH
mj
08-20-2006 12:46:40
 Re: Welding exhaust manifold in reply to KEH , 08-19-2006 15:49:08
Try this link.
Chester
08-20-2006 09:22:02
Another view:
http://www.lincolnelectric.com/knowledge/articles/content/castironcrackrepair.asp
george md
08-19-2006 21:30:15
third party image
KEH,
If you have holes rusted in the manifold , that is a good reason to keep the arc weld away from it , as you will make bigger holes. But if you use oxy/acet cast iron rod and flux , you can not only repair the hole , but you can thicken the area so that you have a good repair. In the world of cast iron repair the best choice
is o/a torch and cast iron in stick form, next best choice is brazing (work best of items that
are not heated and cooled in their normal life),
the absolute worst choice of repair is arc weld as the rate of contraction of the weld material
is way more than the cast . That is why they go
click when they cool . Below is a link to some cast repair and some other things . Go to the web site and in it there is a link
to image event and in there is a sequence of repair of an extremely well rusted manifold ( called Kelvins manifold ,it's an MM JTU 1939)
The picture shows how thin a piece you can weld
with a torch .
Stan in Oly, WA
08-19-2006 18:08:36
There has been a lot of discussion about welding cast iron on this forum, some of it extremely informative. You might try going to the archives and doing a subject search. I can guarantee that the problem won't be getting too little information.
All the best, Stan
dr.sportster
08-19-2006 18:04:01
If you want to try welding now you will have to get all the brass off it.Welding after brazing wont work well at all.George from MD showed some[amazing] manifold restorations he did once on here.Of course Im sure it aint free either.
Skyhawk Greg
08-19-2006 16:26:04
KEH, I'm not much on personal experience here, but a good site to go to is:
Link
Do a search for cast iron. It appears that you can use E-70 Mig wire to repair cast iron manifolds. Grind clean, preheat and slowly cool it down after welding. There are some much more exotic methods listed as well. As for your questions, there is a technical area to discuss this type of thing in the forum. I have used this several times, and have been quite pleased. Greg
KEH
08-19-2006 17:29:43
 Re: Welding exhaust manifold in reply to Skyhawk Greg, 08-19-2006 16:26:04
Greg,
Thanks for info. Interesting site.
KEH
Ozlander
08-19-2006 20:30:07
 Re: Welding exhaust manifold in reply to KEH , 08-19-2006 17:29:43
Many moons ago, I had a cracked manifold on a 350 Chevy. Took it off, clamped it to a heavy angle iron and welded it with some nickle rod. Never had any more trouble with it.
If you don"t know you can"t do something, it makes it a lot easier to do it.
Ozlander
08-19-2006 20:21:06
KEH
08-20-2006 11:41:58
 Re: Welding exhaust manifold in reply to Ozlander, 08-19-2006 20:21:06
Thanks, guys.
I really appreciate all the replys, some very interesting links. The maniflod in question is not mine, I was asking for info and got it. This manifold is on a 30 year old Case track loader. The owner has just rebuilt the undercarriage so I think he can stand to buy a new manifold. Its really in bad shape, would need patches in three places. Might be worth it to repair an antique that did not have parts availiable but IMO not cost effective here, anyway, not my decision, but I will file the info for future use.
KEH
Slowpoke
08-20-2006 23:47:57
 Re: Welding exhaust manifold in reply to KEH, 08-20-2006 11:41:58
Use it for practice. When the time comes, you'll know how to repair one that has no replacement and be able to do a good job.
