No, they are not poor quality batteries, although they do store energy in the form of an electrostatic field. Here's what happens. If I apply a voltage across a capacitor, the voltage (electrical pressure) will push electrons onto one plate and pull them off the other, until enough charges have moved such that the electrostatic voltage between the plates is equal to the applied voltage. One plate now has a negative charge (extra electrons) and the other has a positive charge (missing electrons), and I have stored energy in the form of the electrostatic field between the plates. Now, lets look at the case where I apply a DC voltage to a capacitor. When I first apply the voltage, such as closing a switch, there will be current flowing across the capacitor until the voltage between the capacitor plates reaches equilibrium with the applied voltage. Once the voltages reach equilibrium, the applied voltage cannot push any more electrons onto one plate or pull any more off the other, and current stops flowing. The number of electrons required to charge the capacitor to a particular voltage is a function of the value of the capacitor, measured in farads (or micro-farads), named after Michael Faraday who first described how a capacitor works. This is why you can test a capacitor with an ohmmeter. An ohmmeter works by applying a known voltage (usually only a volt or two) across the resistance your're trying to measure, and measuring how much current flows. When you first connect the meter, the voltage applied to the capacitor is different than the voltage between the capacitor plates, and current flows and the capacitor shows a low resistance. As soon as the capacitor charges to the test voltage, current stops flowing and the meter reads a high resistance. Now consider the case where I have a constantly changing voltage, such as the 120 volt AC in your house, applied across a capacitor. Because the applied voltage is constantly changing, electrons are constantly flowing onto and off of the plates trying to keep up. And yes, the direction of the charge changes 120 times per second. Capacitors are used to induce a phase shift (change in time relationship between current and voltage) to create a rotating magneitc field in a motor. In a pure resistive load, the flow of electrons is directly proportional to the applied voltage. However, in a capacitor, the flow of electrons is constantly trying to keep up with the CHANGES in the voltage, which means that peak current flows at the point in time during the alternating cycle where the voltage is CHANGING the fastest, not where the voltage is highest. In a simple example (and ignoring a bunch of other stuff for you purists) putting a capacitor in series with part of the winding in a motor causes the current through the winding to be shifted in time compared to the current through the remainder of the winding. By physically offsetting the second winding in the motor, I can create a rotating magnetic field. Realize this is kind of long, but hope its understandable. Keith (practicing electrical engineer, 30+ years) PS...a pure capacitor does not have resonance. Resonance occurs when a capacitance and inductance are paired, and the phase shift induced by the inductance exactly cancels the phase shift induced by the capacitor. Real capacitors may show a resonance at high frequencies due to stray inductance in their construction, but thats an undesireable effect that circut designers try to avoid.
