Tool Talk Discussion Forum
Question about couplings...
Brian in NY
08-18-2006 09:54:07
Ordering lovejoy type couplings for log splitter.
If the shafts I am installing the couplings on don't have keyway slots how would go about grinding down the shafts to allow for the keyway?
I guess my question is how would I grind it down uniformly?
Don-Wi
08-18-2006 22:59:43
 Re: Question about couplings... in reply to Brian in NY, 08-18-2006 09:54:07
If you grind it for a key, you might as well throw it right in the scrap heap. Bring it to a machine shop or atleast a guy witha mill and have a keyway cut in the shaft the right way. I work in a machine shop and I've fixed a few that were done this way. They didn't last more than a month and the hub spun on the shaft, with the key in between. It wrecks the hub so you gotta buy a new one, and the shaft has to either be welded up or replaced. If it's welded it's sometimes a b!tch to cut, espescially if all you got for tooling is High Speed Steel endmills instead of Carbide.
Grinding is out. It'll cost you more in the long run.
Donovan from Wisconsin
Bob
08-18-2006 10:01:32
Install a coupling half. Tighten down the setscrew(s).
Take it back apart, and centerpunch where the center of the setscrew contact area(s) are.
Then, drill a little indentation where the setscrew contact area(s) is.
Then, reassemble it with the tips of the setscrew(s) in the indents.
The next best thing to a real keyway.
Slowpoke
08-20-2006 00:48:57
 Re: Question about couplings... in reply to Bob, 08-18-2006 10:01:32
There's always the cape chisel to cut keyways.
Grainger has them in 13/64, 15/64, & 17/64. About $7.50 each. Be sure to make a couple of practice keyways on a scrap shaft first.
