Tool Talk Discussion Forum
bit size for 1/8 pipe tap
bcPA
08-17-2006 14:25:33
I want to add drain in a oil filter for my super major fordson. I plan to drill adn tap the housing then braze the red brass pipe in place. I dont know what size hole to drill to start before using the pipe tap. Thank You.
Davis in SC
08-17-2006 14:48:04
 Re: bit size for 1/8 pipe tap in reply to bcPA, 08-17-2006 14:25:33
"R" drill, which is .339 diameter. For the best thread, there is also a 1/8 NPT reamer, that cuts the correct taper, prior to to tapping. Are you sure you want to braze the pipe in place ?
bcPA
08-18-2006 21:36:21
 Re: bit size for 1/8 pipe tap in reply to Davis in SC, 08-17-2006 14:48:04
did it today but just used teflon tape and pipe dope. Also drilled and taped oil pan drain plug for same reason. Maybee if i drain occasionally I can catch water before it makes its way into the oil pump and oil filter. I think the super major needs to be rebuilt and just want to put it off for a while.
