Tool Talk Discussion Forum
Charging Deep Cycle Battery
john-mi
08-17-2006 11:51:53
Stupid Question. Do you need a special charger for deep cycle batterys? What is the proceadure if you use a regular charger. Thanks.
IH2444
08-18-2006 06:45:35
 Re: Charging Deep Cycle Battery in reply to john-mi, 08-17-2006 11:51:53
I use a 10 amp manual charger on my deep cycle batteries and check them with a hydrometer to check the charge. This is one sure method to assure a full charge.
T_Bone
08-17-2006 23:55:01
Hi John,
Depends on what you what to accomplish. If you want a 90% to 95% state of charge over many hours and using alot of water (maintance) with lowering the overall life span of the battery, then a regular charger will work just fine.
Now if you want a 100% state of charge, maximum life cycles with a fast recharge time with very little water maintance then you want to use one of the new PWM deep cycle chargers.
What the new PWM (pulse width modulated) regulators does is pulse the current into the battery as it charges. This allows a high current flow into the battery while keeping the battery cool thus recharge time is cut to just a few hours from 50% discharge to 100% recharge.
As the deep cycle battery nears a 95% state of charge, it then trickle charges too 100%. After reaching 100% then it will go into a float charge mode.
Float charge mode is where the battery plates are desulfurnated thus will produce many more life cycles that a battery that is not float charged.
Water maintance is very high with the old method of recharging. You have to add water about every 30days or so. The water is used up during the recharging during the final topping off charge that creates hydrogen gas and oxygen from boiling the water. The charging also creates a magnetic field that seperates the water into hydrogen and oxygen.
With PWM recharging the battery stays cool during the topping off charge and desulfurnating thus water usage is cut to about once per year.
What's great about the PWM recharging as it can be applied to wet cell battery's or gel cell battery's with the same regulator. You can get a new PWM 10amp regulator for about $45 to replace the regulator in your old type recharger if you understand basic electicity.
T_Bone
John T
08-17-2006 17:52:11
The basic answer is NO you dont need any special charger and regardless what charger you use and provided it has an adjustable charge rate, my advice would be to give her a longgggg g slowwwww www lower current charge. My RV charger is purposely designed for use with and for charging a deep cycle Marine/RV Battery and it is a slooooo oowwwww w charge also and I would say they are indeed a "special purpose" charger especially for those deep cycle batteries, but you can still get by without it even if its not as good as the "special purpose"
John T
mph
08-17-2006 16:00:33
Being Iam cheap I use only one bat. charger and works well on all.But have settings from maintaine [low trickel], 10 amp, 40 amp, 200 amp[boost start]. How ever on deep cycle I always use the lowest setting, and about 2 days on the charger[make sure of water level first] the deep cycle takes a charge s l o w e r. And don't use deep cycle in a series with standard bat. it never will get fully charged. Just my 2cents worth.
landlord7012
08-17-2006 15:54:56
I charge at 12 amps till it kicks out (automatic), the 2 amps for 12 hours. Nice full charge, full day of boating including electric trolling. Just can't bring myself to spend what they are asking for deep cycle charger...
Dave from MN
08-17-2006 14:22:46
I have been told that a deep cycle charger will give a deep cycle battery a full charge, a regulay charger will not. I tested this this summer with 2 of my deep cycles a few times. I would charge them with my regular charger till it stopped charging and said fully charged. I put them then on a deep cycle charger and they charged an additional 4 hours before the deep cycle charger reset as full charge. I also noticed that a "full charge" on the deep cycle charger would far outlast a day on the water, than when I only charged the batts with my regular charger. So IMHO- I would charge em with a deep cycle battery if you have one.
wfw
08-17-2006 12:39:20
not a stupid question if you do not know!! I just use my regular charger
