Plans for Hydraulic Press
Robert J Spence
03-19-2001 09:55:06
Does anyone have a set of plans for a 40 ton hydraulic press?
If not does anyone own one that could tell me what size material i need to build it out of?
Thankyou.
BFO
03-22-2001 05:36:10
 Re: Plans for Hydraulic Press in reply to Robert J Spence, 03-19-2001 09:55:06
If you have a Princess Auto near you, stop by and measure up one of theirs. They usually have a 50-ton or 30-ton on display.
T_Bone
03-20-2001 08:51:24
Hi robert, I would look at using used railroad iron as it's cheap and very stong. I bought 5-10ft pieces for $50 of 120lb/ft rail.
T_Bone
Ken McWilliams
03-19-2001 10:00:10
Robert,
The ones of this size I've seen are constructed of 6" channel minimum. If you have access to 8" channel I would recommend them for the horizonal pieces due to the side loading on them.
The posts would be fine at 6" because the loading is applied through their length dimension.
KRM
