Tool Talk Discussion Forum
Light FixturesInsulation
Glenn FitzGeral
08-15-2006 20:58:21
In installing 4 bulb, 2 ballast florescent light fixtures in my shop, due to a low ceiling, many of them are pressed into the fiberglass insulation bats above. I have not yet hooked them up to the power. Is this a fire hazard?
Thanks, Glenn F.
David - OR
08-16-2006 10:56:10
 Re: Light FixturesInsulation in reply to Glenn FitzGerald, 08-15-2006 20:58:21
"High Output" type fixtures are not supposed to be
mounted flush to anything. These are the "strike down to -20" types with the magnetic ballast, and take HO tubes. The ballasts get quite hot.
Two ballast, 4 tube lamps are probably not "high output" types, especially if they take electronic ballasts. They are probably OK to mount flush to non-combustible surfaces like drywall. Bare fiberglass is probably OK too. Heat buildup in the ballast should not be a problem, but check for any labels contra-indicating this type of mounting.
I would not allow the ballast area of any fluorescent fixture to contact the kraft paper vapor barrier of faced fiberglass batts. The paper is just too flammable.
