Tool Talk Discussion Forum
Setting the timing on a 83 Cutlass
ScottP
08-15-2006 08:32:00
A friend of mine has been restoring his 83 Cutlass and needs to set the timing. The tune up label on the fan shroud said to ground C-3 to kill the computer controlled advance. Where is C-3 located?
He has 2 diffrent repair manuals for the car and neither one tells where this C-3 is. This car has a 307 or 5.0 liter engine.
Thanks
Scott
Revredneck
08-17-2006 06:15:18
 Re: Setting the timing on a 83 Cutlass in reply to ScottP, 08-15-2006 08:32:00
Scott, Be sure to read the instructions on the label carefully. If memory serves, you have to set the timing at 1000 RPM, not at idle. I don't know why exactly, but it makes a difference. Hope this helps. Good Luck and God Bless, Tommy
RJ-AZ
08-15-2006 17:45:37
There is a loose wire on the firewall with a green plastic end on it. Ground that to make all base timing settings. If you unplug the distributor it won"t run.
ScottP
08-16-2006 08:27:42
 Re: Setting the timing on a 83 Cutlass in reply to RJ-AZ, 08-15-2006 17:45:37
Thanks RJ
I'll tell him what to look for.
Scott
joseph brasfield
08-15-2006 08:44:49
if car has eletronic ingiton unplug the harness
where it plugs together coming from the distuber
that way you can set the proper timing
