Tool Talk Discussion Forum
Tool / implement for logging
Tom in TN
08-13-2006 11:54:03
I'd like to cut some trees and skid them to a collection point where I could have someone load and haul them to a sawmill. I have a Ford 2000 tractor without a loader. I have heard about an implement that can be backed over a downed log, winch the front of the log off the ground, and then towed out of the woods with the back end of the log on the ground and the front end of the log suspended off the ground.
Do you know what these things are called?
Thanks,
Tom in TN
RWK in WI
08-14-2006 07:33:52
 Re: Tool / implement for logging in reply to Tom in TN, 08-13-2006 11:54:03
I have a rear facing digging scoop and have raised the log with a chain and put a block under the log put the raised end of the log in the scoop and chained it in place raise scoop to clear obstructions and drag the log. A good logging arch sometines can raise the whole log and keep it out of the mud - you will get a higher price for clean logs.
Tom in TN
08-13-2006 18:13:49
 Thanks guys - just what I needed in reply to Tom in TN, 08-13-2006 11:54:03
Thanks for the info guys. It's just what I needed to know.
Tom in TN
JV3CII
08-13-2006 13:08:02
There's a very nice homemade one on the MBN.
Cheers, JV.
TimV
08-13-2006 12:04:54
Tom: Generically, they're know as a logging arch. These are usually towed, with the log suspended under the arch. Also, Farmi makes a line of logging winches that go on the back of your tractor and will winch a log in from a ways away, then the winch is lifted and you drive away with the log.
jim1650
08-13-2006 11:57:30
my frenid has one here in new york but his has a cly. on it and picks the whole log at way it cut down on the mud
KEH
08-13-2006 15:08:41
 Re: Tool / implement for logging in reply to jim1650, 08-13-2006 11:57:30
Wrap log chain around one end of log, leaving both ends of chain with some slack in them. Put drawbar in 3ph. Back tractor over end of log with chain on it and lower 3ph drawbar as low as it will go. Hook both ends of chain over drawbar, leaving as little slack as possible. Raise 3ph. Log should pick up off the ground. Pull carefully as the log is very heavy. This will not work with large logs, like maybe 2 feet in diameter. Cut logs to length first so they will be as light as possible. GO SLOW, logs can be tricky.
KEH
Ryan - WI
08-13-2006 20:00:58
 Re: Tool / implement for logging in reply to KEH, 08-13-2006 15:08:41
This method will work. So will pounding in nails by shooting the heads with a 22. If you do it this way and do it incorrectly, it will kill you. A logging arch is much safer.
