Tool Talk Discussion Forum
Welder Replacement
Eddie M
08-12-2006 18:34:53
My old Miller Matic 35 S wire welder has finally just about wore out. Any suggestions on what to buy for a replacement?
I don't do as much as I used to but want something that can handle about the same material the 35S could.
Been a long time since I went shopping for one.
Don L C
08-13-2006 19:07:48
 Re: Welder Replacement in reply to Eddie M, 08-12-2006 18:34:53
Check with your Miller dealer....A good 250 traided in would make a good one....thats what I have.....Don
Stan in Oly, WA
08-13-2006 09:56:03
Hi Eddie,
If you could tell us the amperage of your 35 S, as well as any of its most important specs (duty cycle @ full power, etc.) more people could provide personal insight on comparable machines.
All the best, Stan
Steve Crum
08-13-2006 07:47:34
Eddie, That should be a no brainer. You've had good results with the Miller so stick with Miller.
There are a lot of welders on the market today and most are not worth lugging home after you have used a good one. Even if you do less work that you used to, you won't like anything less than you had. Check and see what Miller produces now that is comparable to what you had, then check fleabay and other sources for a decent used one if you can't justify the cost of new. All I use in my shop are Millers for welding and Thermal-Dynamics for cutting.
Eddie M
08-13-2006 08:14:10
 Re: Welder Replacement in reply to Steve Crum, 08-13-2006 07:47:34
I agree Steve. But since it's been quite awhile since I bought one I was wondering if manufacturers had changed from good to bad or vice versa. Even though I don't do as much as I once did I still would like to be able to handle thicker stock if the need arises.
Appreciate all the info and suggestions.
evielboweviel
08-13-2006 13:25:51
 Re: Welder Replacement in reply to Eddie M, 08-13-2006 08:14:10
stay with Miller or Hobart and step up to a 180 think you will like it better
Ron
BobOHIO
08-12-2006 20:04:33
Hi Eddie- I'm not familiar with the 35 S model, but I bought a Lincoln Pro Mig 175 from Lowe's last Fall and like it. I just do small jobs at home and not everyday. It works good for me. Has 30-175 amp range. I think 30% duty cycle at 130 amps.
