Tool Talk Discussion Forum
Micrometers
MF294-4
08-09-2006 20:45:44
Wanting to buy a 0-6" mic set for general farm shop use, enginge repair, etc. Looking at some on Ebay. Do I need to get seperate mics with .0001 graduations or is a mic with interchangeable anvils OK and .001? What about the imports, anyone had any experience with them?
wdtom
08-13-2006 17:21:56
 Re: Micrometers in reply to MF294-4, 08-09-2006 20:45:44
Get the .0001 graduations if you can. If not, don't worry about it. You can estimate down to a quarter thou pretty easy with a .001 reading mike , and most of us don't need to measure much closer or more accurately than that.
Al m
08-13-2006 06:10:28
I would recommend getting Mitutoyo or Starrett if you can.you can get them with .0001 graduatiion on the barrel if you wish but unless you have some percice machines and am into aero space or the likes I would say .001 graduations should serve the average farmer(or machinist)well.I also recomend sets(0-1,1-2,2-3, etc).
Al
John in Ct
08-10-2006 13:44:56
Buying used ones can be good or bad. I lucked out and bought a used Brown and Sharp 0-1" on Ebay for $6 and it checked out on a standard block set. The way I figure, if you buy a top quality one for next to nothing and if it is junk just chuck it or use it for rough work.
John Garner
08-10-2006 12:58:25
Six individual micrometers will serve your needs much better than a single large frame micrometer will extension anvils unless you are dealing with very extraordinary circumstances that make weight or storage volume critical.
I'll buy used measuring equipment ONLY if I can personally examine it before purchase. You'll need to make your own decision about buying used equipment through ebay and the other internet auction sites.
From what I've seen, the micrometers imported from Poland are great values, offering excellent performance at a very reasonable price. They are getting harder to find, unfortunately, as some of the mail order suppliers have replaced the Polish tools with a "higher-end Chinese" line that look VERY much like the Mitutoyo micrometers.
When it comes down to it, either the Polish or the Mitutoyo-looking Chinese micrometers should serve you well for many years. The Polish micrometers will need a good cleaning to remove the preservative grease layer and probably will need minor adjustment to zero correctly. The Mitutoyo-looking Chinese will need the cleaning and more likely than not a major adjustment to get them working right. A zero-to-six inch set of either of these, with standards, and in a wooden box, will probably run around US$ 100 from a mail order supplier (ENCO, Travers Tool, J&L Industrial, Victor Machinery Exchange, and so on.
These places also sell the "standard Chinese" micrometers for US$ 20 or US$ 30 less. These micrometers will need the cleaning and probably a bit of deburring to get them working right. Although I've seen a lot of these micrometers in machine shops, I don't think they're worth buying unless A) cash is REALLY tight for you, and B) you know how to clean, deburr, and adjust them.
Western European imports are usually excellent, but often higher-priced than American-made micrometers. Starrett is probably the highest-reputed US micrometer, but Brown & Sharpe and Scherr-Tumico are comparable. The two major Japanese players are Mitutoyo and NSK, and their micrometers are indistinguishable from the US and Polish models in terms of their quality.
All in all, I'd say "Go Polish" if you can.
Brad in WI
08-10-2006 10:04:26
Go with the individual mics. Some people will only use the best while others use only cheap ones. If you take care of them, being gentle and keeping them clean, even a cheaper set will last a long time. They will not be used everyday as in a Machine shop and alot of persons in the machine shop that I work at have the cheap set from MSC or Enco.
george md
08-09-2006 21:46:14
Interchangeable anvil mics are not very handy to measure small items, a 6 inch frame is quite bulky to measure a 1 inch shaft , and very difficult to
use up inside an engine block to measure a rod
journal. In my machine shop I have several brands of mics,
some starret,some Brown & Sharp ,a few Central
Tool, a set of made in poland 0 to 6 from MSC and
a cheap set of 0 to 6 from china to keep in the service truck . Of the american made ones ,B & S
are the best and the polish set are as good .
Starrett is hard to read and central will slip an adjustment once in a while .
The polish set from MSC were just over 100.00 and
are very consistent, and easy to read as well as
being comfortable to handle. The made in china set from Enco seem to be alright but I don't use
them much , They were 89.00 from enco. george
