RE: battery welder
carl
03-18-2001 17:53:14
I've heard of 12v and 24v stick welders, operating solely off car batteries. I'd like any input,and a source to buy or a schematic to build one. It seems like it would be perfect for some of my remote repairs. THANKS
John Ne.
03-19-2001 10:21:08
 Re: RE: battery welder in reply to carl, 03-18-2001 17:53:14
Here lately have seen a tiny wire welder attached to a portable 12V jump box, factory made thing, price wasn't too bad either, thought it would be perfect for going up on a grain leg, or inside a truck box. Auto parts stores are carrying them. Just can't tell you how well they work. Repair tech in a factory once told me he usually welded off the big batteries in his fork lift, rather than cart his 300 lb. welder all over the plant. Wish I knew what size rod he used. John
Tibor
03-19-2001 07:42:04
Carl, here's the url for the site with plans for a portable and an onboard welder. Go to the home page also, he's got other goodies on there (bottom of page link).
http://www.huv.com/jon/jeep/Welder/portable-welder.html
Al English
03-19-2001 04:47:37
Hi carl, I once measured the voltage across the arc of a Lincoln 225 AC welder. The voltage varies with arc length, but it was about 12 volts...Al English
Salmoneye
03-19-2001 03:41:51
I saw a guy tack a muffler pipe back together on a backcountry 4-wheeling trip.
All he did was disconnect the battery on his Jeep and hook up a set of jumper cables (big fat ones) to it. One lead he hooked to the pipe and in the other one he stuck a welding rod. I have no idea what rod number or size, but it worked. He got a good aim and then closed his eyes for each strike.
I am not recommending this!!! Just stating that I have seen it done...
hay
03-19-2001 03:32:54
sears has a portable welder in their tool catalog.
rhudson
03-18-2001 21:51:44
Mother earth news had plans for one years ago. was made from a lawn mower engine turning an auto alternator with a deep discharge batt. if i recall correctly, it would only work with small dia rods. sorry don't rem. the actual date.
Norman
03-18-2001 18:43:54
This welder is actualy A high output alternator with a control box to plug your leads into.you might be able to order one thru your local auto parts house.
