Tool Talk Discussion Forum
Source for approved plastic air lines...
Gumby
08-09-2006 06:54:23
The subject of alternatives for compressed air lines has been beat to death on several chat rooms over the last couple years. Someone had posted a web address for a company that manufactures approved "plastic" components (NOT PVC) for compressed air lines. I had the address at one time but can't seem to find it, and my internet searches have not proved successful. Anyone know of any companies that produce a product specifically for compressed air lines that the do-it-yourselfer could install in his shop or garage?
Thanks.
oldrustycars
08-09-2006 15:00:15
 Re: Source for approved plastic air lines... in reply to Gumby, 08-09-2006 06:54:23
i'll second the vote for truck air lines. my new Mack operates at 135 PSI, im sure burst pressure rating is way higher. easy to work with too, any truck parts, even most NAPA's can fix you up.
Ron in Nebr
08-09-2006 20:58:42
 Re: Source for approved plastic air lines... in reply to oldrustycars, 08-09-2006 15:00:15
What's the diameter of the truck air lines(and the other lines listed below too)?
I know on a regular air hose, the difference between 3/8" and 1/2" can sometimes make a big difference on the performance of some air tools. Hate to be restricted by the permanant lines in the shop!
On our main shop we have 1 1/2" black pipe lines, and the extra size really adds to the air storage capacity as well....
Charles (in GA)
08-09-2006 12:36:25
The easiest to work with plastic pipe for compressed gasses (that meet the California specs, which are the defacto national standard) is the Chemair pipe by Nibco. It was too pricey for a while, but with copper climbing it price, its starting to look better than ever. You can get fittings that glue, or fittings with o-rings and lock rings, push the pipe in the fitting and it locks together.
Link
Read these other threads for info also.
Link
Link
Link
Charles
Mike M
08-09-2006 09:57:52
Most every semi truck running up and down the roads today is full of it. Go to a truck garage and get some.
M.R.
08-09-2006 09:35:22
In case the link dosen't work.
Link
neblinc
08-09-2006 09:10:43
I will be checking into this stuff when I get ready to plumb my shop with air.
Randy
