Tool Talk Discussion Forum
Estwing tools
Bus Driver
08-08-2006 14:48:22
I have a couple of Estwing hammers that originally had the stacked leather rings for the grip. I inherited these hammers and know only that they are at least 30 years old and not more than 60 years old. Some of the rings are broken (and gone) and the others are becoming loose. I Emailed Estwing about the problem. Here is their reply: "I'm sorry, but we must comply with industry safety standards that prohibit repairing, regripping or refurbishing used tools and we do not sell materials for regripping.
Sincerely;"
I am sure that this is their final answer. Any suggestions for self-repairing these? Leather rings are not practical for me since every one in the stack is slightly different from the others.
MarkB_MI
08-08-2006 19:57:12
 Re: Estwing tools in reply to Bus Driver, 08-08-2006 14:48:22
It seems to me that it shouldn't be that big of a deal to replace the leather grip. You don't need to cut the rings to the exact size; you cut them oversize, then grind them to fit.
You'll need a piece of heavy leather; you should be able to find something from a shoe repair or leathercraft shop. The thicker the better.
You'll probably need to make a punch to cut the holes in the rings to fit the handle tang. I'll bet you can fabricate something out of thin wall tubing. Maybe flatten a piece of half-inch conduit and sharpen the end. The punch will have to be hollow so you remove material from the center of the hole.
Once you've got a working punch, just punch a bunch of holes in your leather, leaving enough room between the holes to cut your rings. Cut the rings to rough size, then put them on the hammer handle and replace the end piece. Once everthing is back together, shape the handle however you want with a grinder, belt sander or whatever.
Stan in Oly, WA
08-08-2006 17:22:31
Hi Bus Driver,
If you replaced the existing rod that the leather rings are on with a flat tang, or built it up to make one, you could attach a wooden handle that you had sawed in half lengthwise with brass rivets through holes drilled in the tang. I did this once but it was on a novelty carpenter's hammer that I made by cutting the head out of the head of a 20# sledge hammer. I considered it functional, but I doubt that the person I gave it to ever actually used it (certainly not for carpentry.) Knives often have wooden handles attached in this way, but they don't take the beating that a hammer does, so I don't know what the actual durability would be.
All the best, Stan
Brad in VA
08-08-2006 15:01:47
hello, if they are that old im assuming that you inherited them? if so id just keep them for sentimental reasons... as far as getting them fixed, most likely a good leather shop can fix them... check with loccal bikers or at the fairs, flea markets... they cost will be high for custom work but may be your only option... eastwing hammers are really good... we use them for framing houses, barns and fence work... great tools and they can be bought at any lowes for around 30 or less... id buy a new one to use get your old ones fixed and hang them on the wall for memories... my 2cents
CENTAUR
08-08-2006 19:47:58
 Re: Estwing tools in reply to Brad in VA, 08-08-2006 15:01:47
With all due respect to brad of Va.Anyone that repairs any tool is now found guilty of altering the tool&will lose in court.As an ex tool dist.I was warned to never repair a tool for a customer.This went into effect in the mid seventies.A short time later all repair parts were diposed of.The wherehouse manager told me they put them in the dumpster to get rid of the liability.LEN
Ron in Nebr
08-08-2006 20:29:19
 Re: Estwing tools in reply to CENTAUR, 08-08-2006 19:47:58
Wow...now THERE'S one law I sure hope they don't start enforcing! Talk about overcrowding of the courts! If I had a nickle for every tool I've seen that'd been "repaired" I could buy a whole Snap-On truck! We live 40 miles from town, and if our only 25/32nd box end wrench breaks and we need it to finish a repair to get back to the field, that puppy gets welded back together! Hammer and axe heads get held on with bent nails, tape on most any broken wooden handle, etc. etc. etc.
Of course, it could be that this law mainly is meant for tool dealers who "repair" something for customers who might sue 'em. Then again, I've had Snap On men put new gears in my rachets before, and new handles on screwdrivers, and....
CENTAUR
08-08-2006 21:05:18
 Re: Estwing tools in reply to Ron in Nebr, 08-08-2006 20:29:19
To RON and everyone else. I am sorry I said anyone! I made a mistake.I do it everyday.LEN
