Tool Talk Discussion Forum
Craftsman Torquewrench
Mike Veen
08-08-2006 13:43:07
I had a brand new torque wrench from sears,3/8 drive 13" long up to 250 lbs...DID NOT work at all.I tried in a vice at 20 lbs,clicked with my pinky.40 same,80 same,250 for fun,took two fingers.Got a new from sears,same bloody thing again.A new warrany one is one the way so I"ll see what happens,3rd time lucky maybe.Anyone else have this problem.
tech4
08-08-2006 14:38:39
 Re: Craftsman Torquewrench in reply to Mike Veen, 08-08-2006 13:43:07
I think you will find that model is 25 - 250 Inch lbs not foot lbs
Brokenwrench
08-08-2006 14:05:09
I agree with TO. If it"s only 13 in long 3/8 drive, I bet it"s inch/lbs. 20, 40 in/lbs is very light. 80 is only 6 1/2 ft lbs, and 250 is a little over 20 ft/lbs. A 13 in wrench would be pretty useless at 250 ft/lbs unless you got a 2 ft cheater bar. You"d more than likely snap the 3/8 head off it. Good Luck Brokenwrench
TORQUED OFF
08-08-2006 13:49:52
3/8 is only in lbs if I remember correctly. 1/2" is foot pounds.
Mike Veen
08-08-2006 15:41:17
 Re: Craftsman Torquewrench in reply to TORQUED OFF, 08-08-2006 13:49:52
I'm not getting enough sleep...dumb as a stump.Numbcowpoop.
James in North Carolina
08-09-2006 17:09:30
 Re: Craftsman Torquewrench in reply to Mike Veen , 08-08-2006 15:41:17
lol.
Mike it could have been worse. You could have torqued your lugnuts before noticing something didn't add up.
James
