Air compressor
Dan ,michigan
03-18-2001 13:48:17
I bought a compressor that blows air out the intake holes,and oil out the air vent on the block. Its a sears 1 hp compressor.
Roger
03-18-2001 15:19:00
 Re: air compressor in reply to Dan ,michigan, 03-18-2001 13:48:17
The valve plate is probably in backwards or you have broken valves. Possibly a holed piston. Some dipstick breathers will blow if oil has fouled the sponge inside them. They can't pass enough crankcase pressure and they pop like a cork from a champagne bottle.
Dan, michigan
03-18-2001 17:52:04
 Re: Re: air compressor in reply to Roger, 03-18-2001 15:19:00
I pulled the head, the two reed valves under the head cap were dirty and rusty in an open position. The four valves on the head were also dirty and full of grime, with one open and three closed. The piston and rings look ok. The oil in crank case looks pretty bad. The crank seems tight and turns freely ,and looks ok.
Ray,IN
03-21-2001 16:50:54
 Re: Re: Re: air compressor in reply to Dan, michigan , 03-18-2001 17:52:04
Sounds like the prior owner did'nt clean the air filters.
