It is very difficult to predict the primary current on a welding transformer. Its not a simple tranformer but a current regulating transformer that involves saturating part of the core. The magnetization current is a large part of the unloaded primary current, but will depend on the position of that shunt or the coil's position on the core which depends on who made the welder. Then there are many possibilities of design details. A low cost design will probably draw a lot more primary current than an expensive design simply because in any transfomer design there is a trade off between energy efficiency and the amount of iron and copper (or aluminum) used which makes the higher efficiency transformer more expensive because it has more materials which then takes up more room. But it runs cooler. About all that can be said is that if a particular breaker never trips while supplying a welder, the circuit probably had adequate capacity. reputable welder makers will specify the circuit size needed. Then that will be only be absolutely needed for running the welder with the largest rods and maximum current. And unless you are in the habit of welding 1/2" slabs with 1/4" rods in one pass, you may never load the welder that hard. You can learn power consumption with the utility watthour meter, but not current, because the power factor of the typical transformer type welder will be on the poor side causing it draw lagging current likely twice what the watthour meter would indicate. You can measure watts with the watthour meter by finding a value for kh on the face. Often 7.2 watthours per revolution. Time a revolution in seconds. Then that time divided into 3600 x 7.2 is the watts consumed by that load. W = 7.2 * 3600 / t. The load has to be constant for that to be reliable. A welder load often isn't constant. Then if you run a welder that needs a 30 amp circuit on a 20 amp circuit, it may not weld as well because the overloadedd 20 amp circuit will have more voltage drop which leads to poor current regulation. Open circuit voltage may vary from 40 to 75 volts, closed circuit voltage will vary with the arc length. Any measurements of primary current will vary with the length of the arc, the size of the rod, and the skill of the operator. Power factor is determined by the load, the utility prefers a very high power factor. A transformer welder will not present a high power factor under any operating conditions. You could weld with a plain transformer, but then arc current would vary inversly with arc gap and you would blow holes every time you slipped and shortened the gap. My dad built a DC welder using an aircraft generator and it had that characteristic. What you want to know is difficult to know and harder to repeat the test. So what is it you are after? Size of wires to feed the welder? energy consumption of welding? Gerald J.
